Question about Behringer Music
Need a replacement fader for behringer mx 2004 mixer
Fader for behringer mx 2004 mixer
3 Suggested Answers
hmerchant110
  • 7191 Answers
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jan 15, 2010
  • 5603 Answers
SOURCE: LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Posted on Apr 28, 2010
Frustration coming from djx700 mixer left Chanel need help :( on booth and master ??
the faders were actually fails functioning it well, it must be replace a new one!im a audio technician of BEHRINGER!
Aug 04, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
HI, My behringer 32 channel eurodesk mixer's some of the channels not working. No sound for the mike input. Please help. I am in phoenix, where can i take this?
Has somebody spilled liquid into the unit? Are you using XLR to XLR mic cables? If using condenser mics you need Phantom power on else NOT.
If the faders are noisy, use CRC226 in them. You can get that at Home Depot in the electrical dept.
NEVER use contact cleaner such as Deox.it or BlueShower in faders... it wrecks them
Feb 28, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
How to use a mixer board
Input at each channel XLR or 1/4 ", at faders(bottom) are assignment buttons for sub groups or to stereo out put and main faders drive audio to amps.
Feb 27, 2011 | Behringer Sx2442fx Eurodesk 24channel...
Why cant i get the same brilliant sound out of this unit compared to a carlsbro cdx 12x2mgs-fet digital reverb (not sure on these exact model nos as reading this second hand) this one sounded awsome ,but...
The mixer should have the same sound quality... the effects MAY be quite different. It is hard to know what you are refering to regarding sound "quality". One must setup the mixer correctly. Critical things are the trim controls and faders. Your faders should be near the unity setting when adjusted. Setting the EQ'a ia important and if you are stereo usage, setting the pan control can be important.
Feb 25, 2011 | Behringer Sx2442fx Eurodesk 24channel...
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I think my crossfader stop working for some reason. when im on side B i get sound then i slide over to side A and i still get sound from side be,,, all the assign are right also the bass mid and hi kill...
I suspect one end of the crossfader pot has broken from the element. The fader probably costs less than $5.
You likely will have to remove all the knobs and some screws to seperate the board with the fader from the front panel so you can replace the fader.
VERIFY the pot is bad with an ohmmeter before dis-assembling however.
You MAY be in luck. It looks like the cross fader has a connector which MIGHT allow you to remove it or certainly only a small board for replacement, seeing these take abuse.
It appears that the cross fader is a dual 100K type B taper.
Apr 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have a behringer xenyx 2442 and the main output fader no longer works. Each individual channel fader now seems to go direct to the main mix and appears to bypass the main fader
The utput fader has probably been broken. If the knob takes a hit, it breaks the resistance element. The part is inexpensive but it takes a lot of work to access and replace the part.
Oct 14, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I need halp how to plug up my behringer eurorack mx 3242x to my pc
Have a look at the Behringer UCA202. Its a Usb port that should help you do what you want.
May 15, 2009 | Behringer Music
Music Logo
118 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
