Question about Intuit QuickBooks Pro 2007 Full Version (299116)
Need to add additional field on employee timesheet .
With quickbooks pro 2007 we use the employee timesheet and would like to add another field to the timesheet to allow us to show additional general job information (in additional to the field for customer job number).
  • 32 Answers
There is a notes file that lets you add infor concerning the billing - it might be closed up to where you can only see the N, If you use the single Activity window you will see a nice large area to add info. These single activities will all show up on the weekly time sheet.
Posted on Feb 06, 2009
Return icons zed out
The timesheet app designed to work with QuickBooks. Upload your customer, service items and class lists from QuickBooks using a Timer list file (IIF) and start tracking your billable and non billable hours immediately. With a few clicks your timesheets can be imported directly back into QuickBooks for quicker and more accurate billing and payroll. You can also create invoices for billable hours and materials and enter payments received from customers.
Feb 24, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Cant open quickbooks , message pops up error code 8000ffff
If your problem did not solve till now, i would suggest you third party tool which will repair your corrupt QuickBooks file and save your data in working condition.
http://www.recoverfilesdata.com/quickbooks-file-recovery.html
Free to Try Version is Available
Aug 10, 2012 | Intuit QuickBooks Pro 2008: Windows
I am a consultant and I have time and mileage to enter onto the same invoice. I get the time to post but can't get the mileage onto the invoice. It posts to a separate invoice. I have spent hours on this...
How are you entering the time and mileage?
As "Timesheet" entries? or as "Expense Items"?
Assuming that you are using the timesheet (for both the time and mileage) when you create an invoice, QB should ask you if you want to invoice for "outstanding billable items" - when you say "yes" then two seperate lines should appear on the "time" tab. If you select both lines, they are not combined unless:
a) You are using a "Group" Item Type
b) You select both lines, and then you select the option to "print as one item on invoice".
As long as you are not doing (a) or (b) they should appear as two seperate lines.
Feb 11, 2010 | Intuit QuickBooks Pro 2007 Full Version...
Download quickbooks 2007 to a new computer.
Hello Michelle,
You can download it here:
For Quickbooks Pro 2007
http://quickbooks.intuit.com/downloads/2007/pro.jsp
For Quickbooks Premiere 2007
http://quickbooks.intuit.com/downloads/2007/premier.jsp
For other Quickbooks 2007 products, you can choose here:
http://support.quickbooks.intuit.com/support/Pages/KnowledgeBaseArticle/1006369
Hope this helps. Good luck!
Oct 21, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Cannot open Quik Books 2007
Windows XP:
  1. Uninstall QuickBooks, Microsoft .NET Framework, and Microsoft Visual C++ 2005 Redistributable:
    1. Close QuickBooks.
    2. Click the Windows Start button and select Run.
    3. Enter control in the Open field and click OK.
    4. Double-click Add or Remove Programs.
    5. Right-click your QuickBooks program version and click Change/Remove.
    6. Follow the instructions to Uninstall QuickBooks.
    7. Repeat steps d through f to uninstall Microsoft Visual C++ 2005 Redistributable.
    8. Repeat steps d through f to uninstall Microsoft .NET Framework for your version of QuickBooks:
      • QuickBooks 2008 and 8.0 and later:Microsoft .NET Framework 2.0
      • QuickBooks 2007 and 7.0 and earlier:Microsoft .NET Framework 1.1
  2. Rename the QuickBooks program folder:
    1. Right-click the Windows Start button and select Explore.
    2. Browse to C:\Program Files\Intuit.
    3. Right-click the QuickBooks folder for the version you just uninstalled (for example, QuickBooks 2008) and select Rename.
    4. Enter OLD_ at the beginning of the folder name and press Enter (for example, OLD_QuickBooks2008).
  3. Insert the QuickBooks CD in your CD drive, and follow the instructions to install the program.
  4. Open QuickBooks.
Jul 09, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Customerwise # hours billing for a date range..need a report
Use the timeshhets to post the hours. Once the hours are posted in the timesheet you'll be able to pay the gyard and bill the customer at the same time. That is a nice feature of QuickBooks for you're type of company.
www.cpahispano.com
Jun 10, 2009 | Intuit QuickBooks Pro 2008: Windows
Can't "Pay Employees" , I get error message & QB's shuts down
You have to uninstall and then reinstall QuickBooks. I had the same problem and this is how intuit told me to fix it and it worked.
May 02, 2009 | Computers & Internet
Quickbooks Pro 2008 Payroll Setup
QuickBooks will set up both sides of a simple plan if you use the EZ set up.
OPen the payroll item list, click on Payroll item (at the bottom of the window) and then new item. Chose the EZ set up and it will walk you right through it. You can then go in and edit each item (employee and company) as you need to.
PS Please rate my answer as I am attempting to become a premium expert.
Thank you
Nov 21, 2008 | Intuit QuickBooks Pro 2007 Full Version...
Did you set up the simple plan through the ez set up? QuickBooks will automatically default to the USUAL settings -ie employee portion is only taxable at the state and local level)
You might want to check how you have it set up. To do this
Go into the edit payroll item, click through until you find the screen for Taxes and select the items that are affected by the contribution (check with your state and local taxing authorities to see if you need to withhold for the employee portion)
Nov 21, 2008 | Intuit Quickbooks Pro 2008 W/Payroll 2008...
Intuit QuickBooks Pro 2007 Full Version (299116) Logo
135 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
