Question about Bosch Washing Machines
Bosch washer WFT 24 error code 03 - Bosch Washing Machines
SOURCE: washer dryer
There is a switch on the thermostat that may just need resetting. If I remember it is a push switch. This will reset the thermostat and the heating element should start working again.
Posted on Mar 30, 2007
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
  • 298 Answers
SOURCE: I'm staying in a rented
you can try and go to appliancerepairplanet.vstore.ca to see if they can get you a sevice manual on your model
Posted on Dec 15, 2010
pcsuperhero
  • 97 Answers
SOURCE: need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Posted on Dec 22, 2012
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2013 | Bosch Logixx WFT 2806 Front Load...
How do I clear code E27 from my Bosch washing machine?
I had to call a certified bosch repair center. They sent someone out who entered some sort of code to put the washer into diagnostic mode. Once it was there, the code cleared and my washer worked again.
I asked for the code, and the repairman wouldn't give it to me.
Aug 31, 2010 | Bosch Logixx WFT 2806 Front Load...
F:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Jul 07, 2010 | Bosch Logixx WFT 2806 Front Load...
Bosh wasching machine wfr2830 error code 7 Anybody knows wht's the problem? thanks
I am factory authorized Bosch service and parts supplier and love the Bosch products.
Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.
Thanks, Ella
Nov 15, 2009 | Bosch Logixx WFT 2806 Front Load...
I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Logixx WFT 2806 Front Load...
My Bosch washing machine (logixx 8) shows error code F37 and beeps
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 06, 2009 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
