Question about Campbell Hausfeld Garden
I need diagram for Craftsman 2200 psi Gas Pressure Washer with 4.5 hp Briggs and Stratton Engine
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
SOURCE: 2200 psi husky briggs and stratton pressure washer
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
Posted on Jan 30, 2010
mkh5094
  • 145 Answers
SOURCE: Oil
Remember when your searching for something you can't find the internet is always your best bet. You should also use a good search engine; www.bing.com is one of the best search engines I have ever used. I searched some stores that have the oil your looking for, one online store is www.amazon.com and if you have one near you and they also carry it at Sears. The grade of the oil is definitely weird, 75W90. Also if you would like to look for other stores that carry it go to Bing and type "Briggs & Stratton Pressure Washer Oil" into the search bar.
Posted on May 23, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
  • 36 Answers
SOURCE: started by Craftsman 2700 PSI
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
Posted on May 09, 2011
How do you fix a bad suction system on a 2200 ?
I'd love to help but need more info. Look for the model # on the base frame sticker.
then can you give me a better description of what you need.
May 16, 2014 | Briggs & Stratton 2200 PSI Gas Pressure...
Engine lockup
Sounds like the intake or exhaust valve is not opening.
Jun 08, 2013 | Craftsman 2700 PSI Briggs Stratton...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Engine runs fine but will not spray
Check all of your inlet hoses, one may have a kink or a blocked up filter screen. If nothing is clogged your pump has broken and will need replaced.
Mar 01, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
Pull start won't pull. Engine was running then stopped. Now the pull cord won't extend
First. Turn off the water....Release all of the pressure off of the hose and pressure washer. Try and pull again. If it still won't pull check to see if there is oil in the engine. The engine may have locked up.
Feb 12, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
Oil
May 23, 2010 | Briggs & Stratton Briggs Stratton 2000...
I have a Blue Max high presure washer, 2200 psi.
Hi Greg. Walk into your nearest Lawn Mower parts supply with your engine model number (usually on the recoil) and they will have the replacement part or repair your old one. It is less expesive to have the old one repaired unless the support struts have broken. 2200 PSI should have a Honda GX160.
engine:
Here is another source....
http://www.northerntool.com/shop/tools/product_200327175_200327175
They can range from $32.00 to $68.00 depending on source.
Honda PN is: 28400-ZH8-013ZA (do net search this number) Or call your local Lawn Mower repair Supply with the number.
If you have a Briggs & Stratton engine I will need the ENGINE model number off of the air shroud just above the spark plug.
Thanks for using FixYa.
Kelly
Apr 05, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
2200 psi husky briggs and stratton pressure washer used 2 years never used soap dispenser trying now is not drawing soap no longer have manual to see how to connect adjust can you help?
Jan 16, 2010 | Briggs & Stratton Gas Pressure Washer...
Hello:
Aug 25, 2009 | Briggs & Stratton Garden
Garden Logo
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
