Question about AOC 2436swa 23.6" 16:9 Lcd Monitor, 5 Ms - Black
LCD AOC 2436Swa is stuck on active-off mode
My monitor was working when I left the room and the computer went to sleep. I woke the computer from sleep but the monitor wouldn't come on, only the amber light on the power button is blinking.
    Genius:
  • AOC Master
  • 2,432 Answers
Tried to unplug the unit and don,t use for a while to reset the power supply as will as the main board.
Posted on Jan 08, 2013
bammbammfran
  • 159 Answers
SOURCE: AOC lm720 no screen plus blinking green light
Sorry to say, but it sounds like you power board is due for an overhaul.
It should be fixable since it does show signs of a little life left in it.
It would have to be taken apart. A visual may tell for sure.
Look for bulging capacitors (canister looking things) This a sign of a typical failure.
Of course, not all capacitors bulge when they go bad. That would make things too simple !!
ebaysbammbammfran
Posted on Oct 12, 2008
kjanx
  • 194 Answers
SOURCE: AOC LM729 17" LCD Monitor
the inverter needs to be replaced
not real hard, but must have some knowledge of the process
Posted on Feb 02, 2008
Benimur
  • 6966 Answers
SOURCE: AOC LM700 17" LCD Screen switches to black and then comes back to norm
According to LCDParts, an inverter for an AOC LM700 would cost $69.99. Specs (with picture) are available here.
Perhaps you can do a Google for lesser priced versions.
Good luck and kind regards.
Posted on Feb 08, 2008
  • 33 Answers
SOURCE: aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Posted on Jul 10, 2008
  • 1684 Answers
SOURCE: Same problem--AOC monitor "goes to sleep" after an hour online
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Aug 10, 2009
Testimonial: "Buddymc gave a swift and detailed reply to my first inquiry, very much appreciated."
I just added a LCD monitor to my eMachines ET1331G desktop computer. Everything worked fine until I left it on for a day. The computer went into sleep mode and now I can't get it to wake up. I've trie
You should be able to just press the main system unit power button to wake up your 'sleeping' computer which will then resume your Windows desktop and bring you back to the Login panel if you have a password set for your account.
Dec 29, 2011 | eMachines D Computers & Internet
I have a compaq monitor and it will not stay on it says VGA no signal then it'll say monitor going to sleep. It won't let me do anything else. Also saying recommended settings 1600x900 60 Hz. Can...
This may sound ridiculous, but I recently spent two weeks troubleshooting a monitor that wouldn't display properly. Turns out it wasn't plugged in all the way. Make sure that it is plugged in properly, and that your computer/device is displaying TO that monitor.
-bin
Aug 25, 2011 | Compaq Computers & Internet
For a long time the monitor wouldn't come on right away when the computer was in sleep mode, or hibernate. I'd move the mouse around and nothing would happen for 2 to 3 minutes - sometimes. Other...
Probably not a setting
If you are on windows : Can you change the power setting in the interim , to stop it going into hibernation - sleep mode
settings > control panel > power options>high performance should be clicked and then click change plan, PUT THE COMPUTER TOP SLEEP > NEVER
Does not solve the intial issues, but tis impossible to diagnose in this forum
Hope it helps
Apr 21, 2017 | ViewSonic VP2030b 20.1" LCD Monitor
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
My iphoneran out of battery and wont charge (i think)
try leaving it on charge for a few hours, otherwise that ipod radio could have damaged it
Nov 02, 2009 | Apple iPhone Smartphone
3 inches of black on both sides of my monitor
I have seen this when using HDMI cables from the computer side.. The TV has a resolution that is not always full screen with TV shows. There is a setting that allows you to "zoom". My TV has 4 settings: normal, stretch and crop, stretch left and right, stretch and pinch (shrug).
Jul 07, 2009 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
Dell LCD monitor quickly goes sleep, on, off over and over
I would recommend that you try it on another computer to see if you are able to reproduce the results. If that is the case you should look at any new drivers, software or updates that have been installed. If the issue continues with another PC, it sounds as though the monitor's power supply is possibly failing. in that case I would suggest you simply replace the whole monitor. Unless you are not shy with a soldering iron. ;) good luck!
Nov 19, 2008 | Dell E197FP LCD Monitor
Viewsonic VG 2030 WM monitor went to sleep and never woke up again. Now has black screen with blue box and "No signal Analog" error message. Have tried restarting, unplugging, replugging, with...
this has nothing to do with monitor because its says no signal, meaning its working!!!
you need to be looking at the computer for possible hardware failures i.e. graphics card, memory and bios reset etc
best regards
Nov 17, 2008 | Computers & Internet
Won't come out of sleep mode
Have you tried getting a second monitor ? then using it to get to the desktop and go to power options and set your monitor to never turn off? after that is done try your monitor again and see if that works.
Feb 07, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Is this monitor connector to PC? is yes most probably the problem is the system is not sending signal to tell your monitor to wake up...
Aug 30, 2007 | Sharp 17" Monitor
AOC 2436swa 23.6" 16:9 Lcd Monitor, 5 Ms - Black Logo
292 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
