Question about ASUS P5PL2 Motherboard
What is the max. allowable internal memory in Gb in dual channel for ASUS P5PL2
Is 2x2GB internal memory in dual channel within specification ?
  • ASUS Master
  • 3,606 Answers
Hello you can read the spec. here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PL2/#specifications
4 x DIMM, Max. 2 GB, DDR2 533/400 Non-ECC,Un-buffered Memory.
Good luck
Posted on Jan 08, 2013
  • 1 more comment
  • Mike Klomp Jan 08, 2013
    Understood and also found this text in the manual.
    Is it after all 4 memories of each 2 Gb in dual configuration to be total 8 ? Thanks for reply
  • boki_roki2
    boki_roki2 Jan 15, 2013
    yea
Is 2GB DDR2 PC2-6400 800MHz compatible with ASUS P5GC-MX/1333 if not what is the fastest and correct Ram I can fit;
From ASUS Site:
https://www.asus.com/us/Motherboards/P5GCMX1333/specifications/
2 x DIMM, max. 4GB, DDR2 667/533 MHz, non-ECC, un-buffered memory
Dual channel memory architecture
**When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Apr 01, 2017 | ASUS Computers & Internet
What is de max. total memory allowed
Windows 32 bit is 4GB but reads as 3.2 max
64 bit is much more and dependent on hardware and OS. More than you can really use.
Jan 08, 2013 | ASUS P5PL2 Motherboard
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
Can we use DDR2 PC-5300 RAM on P4R800-VM ?
No, you can only use DDR ram.
4 x DIMM, Max. 4 GB, DDR SDRAM ,Non-ECC Memory
Note: Supports one single-sided PC3200 (DDR400) DIMM per channel only
You can see the other specifications here:
http://www.asus.com/Motherboards/Intel_Socket_478/P4R800VM/#specifications
Here you also find drivers and a manual.
Aug 24, 2011 | ASUS P4R800-VM Motherboard
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
Memory problem
The ASUS web site shows only two ram slots on the motherboard. Sounds as if the booklet has a misprint. Specifications on the web site list memory as: Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR SDRAM memory. So, 2GB is max.
Jun 10, 2009 | ASUS P5PE-VM Motherboard
RAM capacity & Soundcard Driver can not be installed
this is the ram specs.
Max Supported RAM2 GB
Memory TypeDDR2 SDRAM Supported RAM Speeds400 MHz · 533 MHz what sound card do you have ?
Apr 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Help!
  • CPU: Intel CeleronD 2.66GHz CPU
  • Motherboard: ECS 661FX-M
  • Chipset: SiS 661FX
  • Devices
    • 40 GB HDD
    • Combo DVD-ROM/CDRW Drive
    • Floppy drive
  • Memory: 128MB DDR333
  • Operation System: Windows XP Home Edition SP2
  • Accessories Box
    • Keyboard
    • Mouse w/scroll wheel
    • Stereo Speakers
  • Features
    • Integrated SiS Real256E Graphics. SMA up to 64M.
    • Open AGP 8x slot, 3 x PCI slots (1 used)
    • 6 x USB ports (4 back, 2 front)
    • Build in AC97 audio codec.
    • 10/100 build in onboard LAN port and 56K Modem
  • Dec 07, 2007 | EliteGroup ECS u-Buddie UB-Em22+ PC...
    Memory swap
    This is the memory specs for your board 4 x 184-pin DIMM Sockets support max. 4GB unbuffered non-ECC PC3200/2700/2100/1600 DDR SDRAM memory Dual-channel memory architecture
    Jun 08, 2007 | ASUS P4S800D-X Motherboard
    ASUS P5PL2 Motherboard Logo
    74 people viewed this question
    Top ASUS Computers & Internet Experts
    David
    David
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
