Question about Canon PIXMA iP3500 Printer
Cyan colour prints fine then stops
When printing a multicolour page, any blue prints perfectly for a couple of centimetres, then rapidly peters out. That's it for cyan until the next day, when it will print similarly. All other colours/black are fine. Canon nozzle deep clean temporarily clears it. The actual image when it starts is perfect, it just seems to run out of cyan ink. New Canon cyan cartridge is in use - I replaced this at first but made no difference. Nozzle head test page shows no bad spots. Is there a blockage between the tank and the actual heads? Can I obtain a new head assembly in the UK if all else fails?
2 Suggested Answers
  • 10406 Answers
SOURCE: Printing colour is wrong, colours come out pink.
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Posted on Mar 09, 2011
My magicolor 2350 has cyan print problem
replace the cyan image unit might go a bad one
Oct 04, 2009 | Minolta magicolor 2350 Laser Printer
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
My hp deskjet 1280 will not print yellow
Hello, this is Harry from
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
May 09, 2009 | HP DeskJet 1280 InkJet Printer
Installed a new cyan cartridge, but the blues show up as pink..
I can assure you that you got a bad colour ink cartridge. However, you may try this: get a small ply of tissue paper and place over the printing head, with your mouth and some good measure of pressure **** it. Repeat a couple of times and all the three colours: cyan, magenta, and blue will show up; otherwise replace immediately. Good luck
Apr 30, 2009 | Xerox Phaser 6180N Laser Printer
Cyan toner problem
Is the section that is not printing down the r/h side of the page?
If so then it is likely that one of your toners is not "locked" in fully. Open the top panel, lift up the orange lever and pull out the PCU. You can now rotate the cartridges, check each one is fully locked in by the coloured levers on the r/h side. Even if one is slightly raised it will block the path of the laser and cause the symptoms that you describe.
Please take a moment to rate this solution. Thanks.
Mar 07, 2009 | Epson Aculaser C1100 Printer
Printer not printing all colours
try to uninstall the driver and istall it again the reboot the system and make a test page or try the alignemet cartridge software
if this is not helping u tell me so i can help u further
please rate this post.
Aug 23, 2008 | Office Equipment & Supplies
Severe banding
u better check the haftone test first,when printer starts to pict the paper,just let the printer to print paper,stop the paper before entering the fuser unit located back side,if the output is perfect,then it is the problem with the fuser assy,pls revert for further solution or query
Jul 19, 2008 | HP LaserJet 2500L Printer
Do you have the operators manual? Run it through a cleaning cycle. Also Xerox's website will guide you through some maintenance steps. If you are using generic wax, you may have clogged the jets.
Aug 02, 2007 | Xerox Phaser 8500/DN Printer
Canon PIXMA iP3500 Printer Logo
old marine
old marine
