Question about Miele Refrigerators
Miele kf 3855 s-6 fridge part not working. Where is the thermostat?
Fridge part of unit does not work. The accumulater thing on the back is not working in any range from 1 to 4. The light comes on when the control is turned from 0 to 1 but the fridge does not cool. I took front panel off to look at the thermostat at the top of the fridge to find only a pcb. I am presuming the problem may be the thermostat. How do i find it please or has anyone have a better idea of what it is. Thanks
  • 1,606 Answers
The PCB is probably the temperature controller and most likely uses electronic temperature sensors in the refrigerator and freezer sections. Not having seen this model before, I'm guessing, but perhaps there is a problem with defrosting such as a clogged defroster drain tube, and the insulation between the freezer and refrigerator is iced up. This could also coat the refrigerator temperature sensor in ice if it is on the divider between the two compartments, thus fooling the controller into thinking the refrigerator is too cold. A manual defrost or drain tube inspection should rule this out.
Posted on Jul 16, 2017
SOURCE: Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Posted on Dec 10, 2007
SOURCE: relay clicking, not cooling either side
asdsad asd
Posted on Mar 22, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
SOURCE: fridge doesn't work but freezer does
i have had the same problem, it was the fan which needed to be replaced.
Posted on Oct 07, 2008
  • 102 Answers
SOURCE: Subzero 590: freezer works, refrigerator not cooling
This is a Sub Zero and many technicians do not realize that these units most all run on 2 separate systems. 2 cold controls 2 compressors 2 evaporators. They share a condenser and condenser fan motor. What you are describing is most likely a bad cold control. It is pretty common for these to get some age and go bad. If you are very savvy with repairs yourself then if you access the compressor area and feel that the compressor on the right is cool and the compressor on the left is warm then you know that the ref. compressor has not been running. UNPLUG THE UNIT OR CUT THE BREAKER OFF. Remove the shelving from the fresh food section and the cover to the lights and the panel below the lights and lean the back panel forward to access the cold control. You will see 3 wires to the cold control. The green wire is the ground wire of corse. Unplug the other 2 wires remembering their location on the control unit. Take a jumper wire and jump these 2 wires. If when you power the unit up the right side compressor comes on then you know that your fresh food cold control is bad. Replace fresh food cold control.
Posted on Apr 11, 2009
The refrigerator and freezer are not working.
Additional information regarding the make, model and serial number would be helpful in diagnosing many problematic issues.
May 02, 2017 | Refrigerators
Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • fan is working as you posted but is the air drawn from the freezer, better still, is the air forced/vented into the fridge?
  • could you please check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 02, 2008 | Refrigerators
The fan on my Miele fridge freezer is not working, how do I rectify this issue
Check first input power supply of fan if its OK then problems can possible in the fan motor . you can check pre fuse by a tester with continuity method
Jul 21, 2016 | Miele Refrigerators
How do I set the temperature for miele fridge freezer pigeon pair kfn 9753 iD?
Wait for it to cool
while it dies you will see flashing bars
it will cool
Feb 24, 2015 | Miele Refrigerators
Hi I have a problem. My Miele fridge K8952 SD ed is cooling more than it should and freezes all the food inside. I can not turn it off and the stat indicates 5 degr C although it is colder inside the...
Can't turn it off, or set higher temp with coin slot thermostat? Might need new one, stuck closed. 5C is 41F which should be great for fridge, but you say food freezes. If need manual to get more info=
Jan 29, 2014 | Miele K8952SDED Refrigerator
How do you stop ice building inside, at the back of fridge model Beko LA87 Larder fridge
It can be 2 things. One is that the thermostat is broken but then it will also freeze your food. The other reason is that it has lost part of its gas charge due to a leak on the system causing the unit not to reach temperature thus not switching of on the thermostat and building ice inside. Normally it is not economically viable to fix the unit.
Oct 06, 2017 | Refrigerators
Zanussi zx99/5 not working ,lights still working but freezer defrosting and fridge getting warmer
sounds like the thermostat inside the fridge has gone.
The information I have provided is a guide and is not directly related to the make and model of the appliance brand you have but seems to cover the majority of household fridge freezers I have come accross. There is a dial inside the fridge usually up on the right side wall of the fridg where the light is. It is usual for the thermostat unit to be inside the plastic housing behind the dial. It is easy to replace the thermostat because I have done it myself and it worked. I am not an expert so if I can do it then anybody could. the unit is usually a standard replacement unit which costs roughly £20.00 available from fridge freezer repair shops. I got my replacement from Sale Appliances, Victoria Avenue, Southend-on-Sea, Essex. The unit comes with the thermometer type wire which fixes to the back of the fridge - inside that is- already attatched to it and all you need to do is remove the screw holding the housing in place (unplug from mains first of course), remove bulb, prise off the plastic housing to reveal thermostat unit, take some detailed pictures of how the wires are attatched or take detailed notes and diagrams, pull off the eelectical connectors (may need a pair of pliers to help, but must be gentle so as not to rip wires out of the connectors), put in new thermostat and rewire as it was before. You will not have to literally rewire the thing but simply slide the wired connectors onto the correct place. The connections are numbered both on the old unit as well as the new unit. Dont worry if the connectors on the rear of the new unit is different to the old one so long as you connect the wires to the same number it wont matter where that connector is located e.g. number two always fixes to the number two marked on the unit, number 3 to numbr 3 etc.
Aug 08, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Miele KFN8462S fridge freezer is displaying an F2 fault code.
F2 Is fridge evaporator sensor faulty it will require new sensor part no.7323301
Apr 01, 2009 | Miele KFN8462S Bottom Freezer Refrigerator
Refrigerators Logo
149 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
