Question about ASUS P5PL2 Motherboard
What is de max. total memory allowed
Maximum internal memory for dual channel
  • 2,878 Answers
Windows 32 bit is 4GB but reads as 3.2 max
64 bit is much more and dependent on hardware and OS. More than you can really use.
Posted on Jan 08, 2013
2 Suggested Answers
SOURCE: Can it support core 2 quad processor? What is the
Yes the motherboard supports Core 2 quad processors, it supports 4GB of memory, for more information go to the link above.
http://www.asus.com/Motherboards/Intel_Socket_775/P5KPLAM/#specifications
Posted on Jul 14, 2011
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Is there any problem if i install a single 2gb memory at one slot on my acer aspire 4315?
max ram per slot is 1gb, for 2GB total. A 2 GB module will not work
http://www.crucial.com/store/listparts.aspx?model=Aspire%204315
Apr 03, 2010 | Acer Aspire 4315 Notebook
How much the memory on compaq v3000z can be increased and what type ddr, ddr2 or ddr3? currently it has 256.
Compaq Presario V V3000 Specification Memory Type: DDR2 SODIMM 200pin DDR SODIMM:
DDR, double data rate is a type of SDRAM in which data is sent on both the rising and falling edges of clock cycles in a data burst. It is usually referred to as DDR as opposed to DDR SDRAM.
SODIMM, small outline dual inline memory module. Smaller and thinner than standard DIMMs, SODIMMs are typically used in laptop computers.
Memory Speed: PC2-4200, PC2-5300 Chipset: Intel 945GM Chipset :
A group of chips that together make up a complete computer processing unit, usually on one circuit board (the motherboard). It may include the main central processor, graphics processors, secondary cache memory, and input-output controllers. Memory is one component controlled by the chipset. Standard Memory: 512MB Removable Memory Slot(s): 2 Max. Memory Per System: 2048MB (2GB) Max. Memory Per Slot: 2048MB (2GB) Dual Channel Memory Support: Supported Dual Channel :
A development in motherboard and chipset design that allows for increased bandwidth transfer when using two or more memory modules in separate transfer channels. These separate channels allow each module access to the memory controller, increasing throughput bandwidth. It is a good idea to use matched pairs of modules to ensure the best compatibility for dual channel operation. Tri-Channel Memory Support: Not Support Tri-Channel :
A development in motherboard and chipset design that allows for increased bandwidth transfer when using three or more memory modules in separate transfer channels. These separate channels allow each module access to the memory controller, increasing throughput bandwidth. It is a good idea to use matched three modules to ensure the best compatibility for tri-channel operation. Install Memory in Pairs: Not Required Install in Pairs :
Memory modules must be installed in pairs of matched memory size. This means that if you purchased your computer with 128 MB of memory installed and you want to add another 512 MB of memory, you must remove the two continuity modules and replace them with two 256-MB memory modules.
Aug 19, 2009 | HP Compaq Presario v3000z Notebook
Memory upgrade problem
Try each stick one at a time in each slot and if one doesnt work, then thats the bad stick.
Is it dual channel?
How many slots total do you have?
Feb 04, 2009 | Intel Motherboard, 945GC, Core 2 Duo,...
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I need more memory on my hp m7248n media center pc, what product should I buy and what is the maximum memory I can get on my computer?
This is from HP.
  • Four 184-pin DDR DIMM sockets
  • Supports dual channel, eight memory banks DDR 333/400 DDR DIMMs
  • Supports 2.5v DDR SDRAM DIMMs
  • Maximum HP/Compaq approved memory is 4 GB* without ECC
4 Sticks of PC3200 400 Mhz is max.
Jan 19, 2008 | Computers & Internet
ASUS P5PL2 Motherboard Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
