Question about HP LaserJet 3390 All-In-One Printer
HP 3390 SCANNER ERROR 3
SCANNER ERROR 3
2 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: how to set up scanner
The home support page for your printer is here, and the setup and install instructions may be accessed from here. You can also download manuals here., so you can have the instructions in your system.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 29, 2009
52 scanner error
In most cases on a unit this old, the laser scanner is failing and would need to be replaced.
Jul 02, 2015 | HP LaserJet 3390 All-in-One Multifunction...
Scanner error 2 how can i fix this?
Hi, check whether the driver of your printer is installed correctly in your pc.
Jul 02, 2015 | HP LaserJet 3390 All-In-One Printer
My hp 3390 is giving scanner error 6 message and this is following a power outage we experienced 02/09/2011. it wont scan, copy or send faxes though we can print and receive faxes. the scanner bulb moves...
this problem causes malfunction of CCD unit, observe that CCD unit moving both directions are not, its sensing the home position or not, even its crossing home position replace CCD, your problem will solve..Vinay...
Sep 05, 2011 | HP LaserJet 3390 All-in-One Multifunction...
How do i open rear output door on hp 3390
At the rear center of the printer, under the scanner/copier, there is a little handle.
Pull it towards you and down.
Jan 27, 2011 | HP LaserJet 3390 All-in-One Multifunction...
My HP 3390 is leaving a line down the center of the page when I copy only How do I fix this. I have changed the toner cartridge thinking in may have been the toner but it is still doing it
Clean the scanner glass. I haven't worked on the 3390, but lift the scanner cover up and clean the glass and see if there is a narrow piece of glass to the left of the big flat bed glass. That is what's causing the line. Scrub it with a little glass cleaner. I bet you don't get the line when you use the flat bed single sheet scanner.
Sep 11, 2010 | HP LaserJet 3390 Printer
Error messages 10 1000supply error for printer 3390
This error implies the print cartridge is not installed correctly.
The steps to resolve the issue: 1.Reinstall print cartridge. 2. Power cycle all-in-one. 3. If the problem is not solved, replace the cartridge.
Hope this helps!
Aug 31, 2009 | HP LaserJet 3390 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
Feb 12, 2009 | HP LaserJet 3390 All-in-One Multifunction...
Printer driver
SOLUTION FOR HP 3055 SOFTWARE INSTALL ERROR!
THE METHOD:
Search for file "DPINST.LOG" on your computer. This will show you specifically what ERRORS are taking place. After three seperate trial and errors I found out that three different files are missing from the software package downloaded from the HP driver support site. http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
"HP LaserJet 3050/3052/3055/3390/3392 PostScript Print Driver Package" ~364mb
MISSING FILES:
UNIDRV.HLP
UNIDRVUI.DLL
UNIRES.DLL
FIND HERE:
http://www.filewatcher.com/m/UNIDRV.HLP.15343.0.0.html
http://www.dlldump.com/download-dll-files_new.php/dllfiles/U/UNIDRVUI.DLL/5.2.3790.120/download.html
http://www.dlldump.com/download-dll-files_new.php/dllfiles/U/UNIRES.DLL/5.2.3790.120/download.html
STEPS:
Download missing files then copy to the unzipped software folder. Which is most likely
"C:\hp_LJ3050-3052-3055-3390-3392_Full_Solution\"
Jun 24, 2008 | HP LaserJet 3055 All-In-One Printer
No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
proper.
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
thanks
Mar 20, 2008 | HP LaserJet 3390 All-in-One Multifunction...
HP LaserJet 3390 All-In-One Printer Logo
170 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
