Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Clothes smell...... I have a tromm washer and dryer.after I was and dry my clothes especially towels and heavy workout wear they come out of the dryer with a very nasty smell....they never smell fresh...my clothes always had a clean fresh smell mostly of downy noe=w they just stink...I have tried bleach and nothing works... any suggestions/
    President:
  • 373 Answers
The following are the methods you can avoid odor in clothes after washing.
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
Good luck.Please do post comments if the problem is still not solved or if there are any doubts in this post.
Posted on Jan 20, 2009
Clothes, especialy towels smell moldy no matter
Same problem here, heavy lime in the water, we had to change to Purex powder with Renezit. Problem is gone!
Jan 29, 2010 | Samsung Washing Machines
Smell after drying
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet.
If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others.
You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
Dec 16, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I have exactly the same problem!
Try using the tub clean cycle and use a good dose of bleach or vinegear. Here is how to run the tub clean cycle.
To start the TUB CLEAN cycle:
1. Remove any clothing or items from the washer and close the door.
2. Open the dispenser drawer and add liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to the detergent compartments. Excessive suds may be produced and leak
from the washer.
3. Close the dispenser drawer slowly.
4. Power On and then press the Extra Rinse button for 3 seconds. (Prewash option will be selected.)
5. Press the Start/Pause button to start.
6. After the cycle is complete, leave the door open to dry around the washer door opening, door seal and
door glass.
Jul 11, 2009 | LG WM2688HWM TROMM SteamWasher
Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
May 28, 2009 | Maytag Neptune Washer
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
Towels smell burnt after washing.
Are you sure the burnt smell is coming from the washer and not from the dryer? If you've placed a rubber backed rug or other similar article of clothing, it is not uncommon for that rubber backing to melt and get embedded in the heated duct of the dryer . Not sure this helps but if you can clarify the point at which the burnt smell is first observed that would help..
Thanks
Aug 31, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Order in clothes
Put a half a cup of vinegar into wash load, with soap. It removes the smells.
Jan 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Washing Machines Logo
218 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
