Question about Asus P5BV-E SAS LGA775 Xeon FSB1333MHz DDR2 800 667 ATX Server Motherboard
I HV PURCHASED P5BV-E/SAS EARLIER BUT TODAY I SWITCH ON THE SERVER BUT THEIR IS NO DISPLAY
  • ASUS Master
  • 3,606 Answers
Hello you can download the manual here:
http://support.asus.com/download.aspx?SLanguage=en&p=5&s=13&m=P5BV-E%2fSAS&os=23&hashedid=zuljCoD6sSH3WpYx
By selecting your windows system.
Open the manual folder and click on global for download.
You need adobe reader to read the content.
This is usually a hardware problem, Video card, power supply, memory sticks or mother
board. To nail down the problem, try the following workarrounds:
1. Does this computer work well before? If yes, what new hardware did you install recently? Remove it and try.
2. Insert one ram module, and turn on the
computer, if the computer POSTs or you hear beeps, try to add one memory
stick each time until you add all your memory sticks.
3. Clear your CMOS by removing the battery or short the jumper.
4.
Swap your hardware from the motherboard, for example, reseating your ram sticks, move video card from PCI slot 1 to PCI slot 2, etc.
5. Reseat your processor, check the CPU for damage.
6. Verify that you have all the power connectors connected properly.
7. Make sure the power supply is working, even test it on another pc.
Remember
to restart your computer after you try any of the above steps. If all
the above does not work, it is very possible that your motherboard is
bad.
Here is a fault finder guide:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Post back what is going on.
Good luck
Posted on Jan 08, 2013
HBA SAS FOR THIS server
Check PCI slot. Is it regular or Express? IBM makes both. You also have options on how many connectors.
Oct 10, 2012 | IBM xSeries (88703ex) Server
Server X3200, when i puched to on the Button, server on, suddenly amber led blinking then server switched Off...... we hv purchased this server last month
Hi!
You can contact the technical personnel of your provider where you purchased the server since its under warranty. Does it function properly when you purchased it? Do you upgrade memory, or hard disk?
thanks
Jun 23, 2011 | IBM x3400 Server
I HAVE ONE X206 SERVER, DUE TO UPS PROBLEM IT WAS NOT SHUTDOWN PROPERLY. NOW POWER IS COMING INTO MACHINE, BUT THERE IS NO DISPLAY. WHAT TO DO NOW?
Since there is no display , we have to reset the ram(Memory).
1: Remove the server cover and remove all the ram from the server
2: Power on the server , check any beep sound comes from server
3: Insert single ram , power on the server, check for display
4: If display comes insert second ram .Repeat the steps till you insert the all the ram
5: If you notice no display while inserting specific ram , just remove that ram
That's all
Note: Each time you inset / remove ram from server make sure the server is switched off. Otherwise it will destroy ram as well as server
Please vote if it helps you
Thanks
Mar 09, 2011 | IBM System x3200 M3 7328 Server tower ...
Performed a clean installation of windows xp sp2 which I purchased and the installation won't complete it says error 1 cannot boot from drive how to fix this ?
you need a raid controler then use a raid driver disk before install windows, because you use sas as primary disk. these disk is for unix and server blade server, using sometimes windows server as Op System.
is a tradicional steps when using special hard disk
Aug 08, 2010 | IBM (40K1042) 36 GB SAS Hard Drive
Ultrium 920 sas install problem
update your SCSI controller drivers and power cycle the server
May 05, 2010 | HP StorageWorks Ultrium 920 LTO-3 Tape...
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
Asus P5BV-E SAS LGA775 Xeon FSB1333MHz DDR2 800 667 ATX Server Motherboard Logo
41 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
