Question about Dyson Memory CRO1 Front Load Washer
Diagram of dyson cr01 showing power board locations
SOURCE: Dyson CR01 front panel removal help
Remove lid, two screws at rear, slide back and lift. Remove control panel, two screws at top, lift and remove ribbon cable. Outer door, open and remove screws from hinge. Front panel, remove two top screws. Front panel lifts up and inch and pulls foward. You might need to move penny trap. To do this, remove rear panel. Right lower hand side, remove motor and mainboard to facilitate space for and arm, have fun! Penny trap and pump are not screwed down. They are hooked over the front metal plate, just lift and pull backwards! I had to remove everything from the machine just to get at the penny trap!
Posted on Nov 14, 2009
Dysonteam
  • 167 Answers
SOURCE: Dyson CR01 - How to clear F8 - Overfilling : Turn Off Water?
Don't panic, simply call our Helpline free on 0800 298 0298. One of our advisors will be able to assist you!
Kind regards
Darran
Dyson Customer Service
Posted on Apr 15, 2010
Dysonteam
  • 167 Answers
SOURCE: Dyson problems
Hi there, try calling the Dyson Helpline free on 0800 298 0298. One of our advisors will be able to run through some checks with you and hopefully resolve this.
Kind regards
Darran
Posted on May 24, 2010
  • 27 Answers
SOURCE: dyson CR01 flowcheck has lost
when my machine did exactly what you are describing it turned out to be the on/off switch on the front panel going open circuit on the live side replaced the switch now working ok check the switch with a test meter making sure machine is disconnected from power supply
Posted on Nov 20, 2010
SOURCE: dyson cr01 outer door not locking, after pressing
This solution worked for me, but there could well be different problems which give the same sympoms. My problem was that the microswitch had become worn with use and the interlock slide would no longer cause the switch button to depress but rather it was trying to push the button sideways.
Remove the 2 screws from the rear of the lid and daw the lid off by sliding backwards then upwards.
Remove the 2 torx screws from the top of the front panel that have now been revealed.
Carefully prise the front panel upwards only on the door lock side until the front panel comes forward giving you access to the interlock mechanism.
Remove the 2 torx screws from the front panel holding the actuator in place and remove the interlock mechanism from behind the front panel, disconnecting the two spade connectors and the door release strip.
Carefully prise the two sections of the actuator apart using a small screwdriver in the slots at either end
You will now see two microswitches connected together by a short wire link.these switches are activated by grey plastic slides, one of which slides when the door catch is engaged in the interlock, the other slides when the first one has been actuated and the solenoid actuates. In my case the first one was worn and was jamming the switch instead of pressing it in.
Remove the two microswitches by prising one off its locating pins and lifting it up then prising the other off its locating pins.
There are 2 very small locking tabs on the switch. Prise them out slightly then the switch side can be lifted off.
Slide out the switch button, rotate it through 180 degrees and place back into the switch. This means that there will be a new face in contact with the actuator slide. Hopeully this will provide another few years of good service.
Rebuild by reversing the previouse steps.
Posted on Nov 21, 2010
Dyson cr01 not spinning
go to the facebook group DYSON CR01 REPAIR.
READ MORE THAN YOU NEED TO KNOW ABOUT THESE MACHINES.
Apr 26, 2014 | Dyson Memory CRO1 Front Load Washer
Dyson cr01 fault F4
Hi Sue, it's Jack at Dyson.
An F4 fault code means 'inner door opening'. Unfortunately since 31st December 2012, we have been unable to support CR01 and CR02 washing machines with spare parts or servicing. In October 2012 proactively wrote to all CR01 and CR02 owners that we'd interacted with within the last 3 years to make them aware of this.
If you would like to discuss your concerns further with one of our experts, you can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
Mar 17, 2014 | Dyson Flowcheck CRO1 Front Load Washer
Dyson cr01 clicking noise
Hi Kenneth, it's Jack at Dyson.
Unfortunately since 31st December 2012, we have been unable to support CR01 and CR02 washing machines with spare parts or servicing. In October 2012 we proactively wrote to all CR01 and CR02 owners that we'd interacted with within the last 3 years to make them aware of this.
Alternatively you may wish to check with local repair services for advice - please note, we cannot recommend or endorse specific repair companies.
Dec 12, 2013 | Dyson Washing Machines
Hi my dyson cr01 is showing a p900 fault could you tell me what this means ? Thanks Rob
Hi Rob,
Sorry to hear you're having difficulties with your CR01 Flowcheck. We don't recognise the error code you've provided, so it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 13, 2011 | Dyson Flowcheck CRO1 Front Load Washer
Kind regards
Darran
Apr 07, 2010 | Dyson Flowcheck CRO1 Front Load Washer
This morning got F11 fault on Dyson CR01 front loading machine, before that drum wouldnt turn and making grinding noises. Dyson have already removed the contra rotating cycle on this machine, is this...
may be the rear bearing has gone,my con/rota packed in and i took the drum out cleaned ,replaced, greesed, and alls well , if it is the rear bearing DON"T let them tell you its scrap if you are good at diy you can take the bearing out and fit new one, bit of a time comsumeing job
Mar 08, 2010 | Dyson Memory CRO1 Front Load Washer
How to repair a F 11 fault on a DYSON CR01 flow check
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Dyson cro1 fault f11 came up after interupted power suply
normally error like this disappear when a hard reset is performed? did you leave the unit turned off by plugging out from wall power for one night ??
The F11 fault is a fuse blown on the circuit board.
Apparently this fuse failing can blow the board so you may have to change the board if needed. The board is located at the back of the machine so you need to take the back off, unplug the board, change the fuse which you can buy at Maplins and put the board back.
If it works fine, if not then you need a new board. Hope this helps you.
First make sure machine is turned off.
Second press & hold temperature button .
Thirdly press the on button & hold at the same time as the temperature button.
Fourthly release the 2 buttons at the same time .
Fifthly press the soil button .
Sixly turn machine off then back on & F11 message saying fault F11 must disappear.
if not try this process once again. if the error is not cleared then you will have to do as i have said you earlier.
Jan 18, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Dyson Memory CRO1 Front Load Washer Logo
154 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
