Question about HP Compaq Presario SR1830NX PC Desktop
How can I fix the hp pavilion tx 1000 black screen? I've tryed to use the blow dry but nothing worked out?
  • HP Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive including electrical extensions IDE SATA the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even something as small as an electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard or you might try You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. If you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope this helps.
Posted on Jan 08, 2013
5 Suggested Answers
  • 195 Answers
SOURCE: hp pavilion a350n computer turns
Never fear, Tripod is here. Send me your e-mail and I will send you what you need. Let me know also if you can use A: floppys? Can you tell me what version of windows? Can you insert a CD boot disk?
Good Luck and don't forget to rate my service after I fixya, Smile, I love to get those I did it ratings.
a-tripod@hotmail.com
Posted on Nov 04, 2008
SOURCE: HP Pavilion tx 1000 tablet
Guru j/k and I spent several hours last night on this problem. We Instant Messaged on Skype and finally figured out that an old expired copy of Norton Security Suite was the cause of the problem, once removed, no mor problem. Guru is the man. He was pleasant, persistent and knowledgable. I highly recommend your service. If the need arrises, I will contact you guys first.
Posted on Feb 08, 2009
SOURCE: HP Pavilion Elite m9517c Desktop PC stuck on welcome screen
hi
there is problem with windows OS
u have to reinstall wondows befor you go for reinstall just tak backup from you C drive
Posted on May 21, 2010
fixya29374
  • 12 Answers
SOURCE: My desktop msg is cannot create file c:\hp\bin\SetRes.log
use your file explorer
go to c:\hp\bin
if it does not exist create it
create an empty file SetRes.log
Now you can try again
Posted on Mar 29, 2012
HP Pavilion Entertainment PC Laptop DV2000
when you say some times it keeps going does this mean the unit turns off ??,,,,this model has the gpu problem,,,dry solder joint of the graphics card, of which you can have the board repaired or replace the board
Oct 06, 2012 | HP Pavilion Computers & Internet
I have a Windows Hp 1000 Mini & The Screen does not turn on it remains black & blank. I've gotten the tip that I must reinstall the Operating System on it. But Does anyone have any Idea ho
Almost all of the HPs Mini laptop screen issues are related to the internal video card/motherboard. hopefully you still have the laptop under warranty.
www.linkedin/in/diaztech
twitter.com/diaztech
www.diaztech.com
May 16, 2012 | HP Mini 1000 Netbook
My HP G62-355DX goes to a white screen randomly and there's nothing I can do to fix it besides turning it off for a while. I've tried unplugging and plugging the video cable back in and I'
TRY HOOKING THE LAPTOP TO AN EXTERNAL MONITOR IF THE MMONITOR IS OK. THEN ITS THE CABLE CONNECTING THE KEYBOARD TO THE SCREEN. HOPE THIS HELPS. THS HAPPENED TO ME GOOD LUCK
Jan 20, 2012 | HEWLETT-PACKARD Hewlett Packard HP 15.6"...
I`m trying to reformat pc. i get to a screen that ask for disk 1. the whole time the disk is in the drive but it won`t read it. please help
there's two possibilities
either the drive the disk is in is going out
or there's something wrong with the disk
I've got 2 hp pavilion desktop computers & I've had the drive go out & cd or dvd also
Sep 09, 2011 | HP Pavilion a1520n PC Desktop
Hp tx 1000 black screen please hel
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Nov 28, 2009 | HP Pavilion Tablet Notebook
I have a HP Pavillion TX 1000. Did everyone heard
It is highly improbable that heat from the CPU can crack a LCD screen. Even if the fan was faulty the CPU would have shutdown (thermal overload) before it would affect the LCD screen. If you apply pressure to the face of the LCD screen or twist the screen or impact the screen with a hard object, any of these will cause the LCD screen to crack.
Jun 11, 2009 | HP Pavilion tx1000z Notebook
Laptop won't boot up black screen
its *********** board. i found a solution for the smae problem on youtube worked like a charm, http://www.youtube.com/watch?v=ctHTF3oNdxI
Apr 24, 2009 | Computers & Internet
HP Pavilion tx 1000 wont start
My HP tx1005au laptop has the same problem after using it for 1 year 7 months. It has power, fan is blowing, but monitor is black. If you keep on trying to start it, sometimes up to fifteen tries, it will suddenly start as if nothing has happened. It is driving me nuts. Hope someone could enlighten us as to what is wrong with this.
Dec 02, 2008 | HP Pavilion tx1000z Notebook
HP Compaq Presario SR1830NX PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
