Question about Simplicity Vacuums
I sucked up a shoelace in the vacuum and pulled it out and now it wont turn on
Blue vacuum
4 Suggested Answers
SOURCE: Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Posted on Mar 26, 2008
Vac Belts
  • 701 Answers
SOURCE: DC 17 Beater Brush won't turn
You need to replace the belt. Here is the belt you need and a manual you can view which has instructions:
Dyson DC17 Belt and Manual
Posted on Feb 07, 2010
VacuumRepair
  • 438 Answers
SOURCE: Vaccum not turning or sucking
It definitely sounds like your belt is broken. If something gets vacuumed up into the brushes, and prevents the brushes from spinning, the motor will continue to try and spin the belt and the brush, but since the brushes can't spin, this will burn right through most belts.
Especially since you mentioned a sock being sucked up, and the roller brush not spinning, this is a tell tale sign of your belt needing replacing.
Here's what you'll need to complete this repair:
- Phillips Head Screw Driver
- Hoover Windtunnel Replacement Belt, Non-Self Propelled, Hoover Part # 38528033
- Depending on how long the sock was stuck in the brush, you may need a new roller brush as well. The roller brush for your model is Hoover Part # 48414110. Here's a direct link for the roller brush for your vacuum on our website:
http://www.govacuum.com/generic-hoover-windtunnel-tempo-fusion-upright-12-inch-replacement-roller-brush-hoover-part-number-4.html
If you have the Hoover Tempo Widepath vacuum that you listed the repair under, then here's a direct link back to our website, govacuum dot com, to the exact belt for your Hoover Tempo:
http://www.govacuum.com/agbelhoovpar9.html
Now, once you have a new belt, this repair is pretty straight forward. I'll explain step by step what you'll need to do to change the belt.
Step 1. Make sure your vacuum cleaner is unplugged. The easiest way to change the belt in your vacuum is to turn the machine upside down, so the handle is on the ground holding it up, then lean the vacuum over a counter top or work bench.
Step 2. Remove the bottom plate of your vacuum cleaner. You'll see on the bottom of the vacuum 4 screws that are located on each corner of the brush, remove all 4 screws, and lift up on the bottom plate that covers the roller brush.
Step 3. After removing the bottom plate, you should now be able to access the roller brush completely, and you'll probably also notice that the belt on the right side of the roller brush is broken. You may just remove the broken belt completely and throw it away. Lift straight up on the roller brush itself to remove it from the vacuum.
Step 4. Test the roller brush. After something gets stuck in the brushes, and it causes the belt to burn, there's also a good possibility that your roller brush may need replacing as well. Also the roller brush will wear down over time, and the brushes will wear down as well, greatly reducing the cleaning ability of your vacuum. You'll want to test your roller brush, to ensure that it spins freely. If it doesn't, then as you install the new belt, it's possible it could also break immediately. To test the roller brush, remove it completely from the vacuum. Holding just the end caps of the bar with your fingertips, try to spin the brush in your hands using your thumbs. This is how it should look when you test your brush (the roller brush is to a different machine, but testing it will work the same):
The roller brush should spin at least 3 or 4 times in your hands on each spin. If the brush will not spin at all, or you feel some resistance when spinning it, then you'll probably want to go ahead and replace the roller brush as well at this point.
Step 5. Once you have your new belt, and new roller brush (if needed), it's time to install them. First wrap one side of the belt over the metal motor pulley in the back of the vacuum, opposite the roller brush. Now after you have one side of the belt wrapped around this metal pin, put the roller brush through the other end of the belt. Using the roller brush as leverage, stretch the belt with the roller brush inside of it back into the roller brush tray. You'll notice that on the left bearing cap on the end of the roller brush, there's a little rectangular shaped notch. Make sure that the rectangular notch is vertical, and slide this end into the agitator housing first, then fit the other side (circular notch) into the housing. With a little bit of elbow grease, you'll be able to stretch the brush with the belt back into place.
Step 6. Test the belt and the brush before putting the bottom plate back on. To make sure that belt and brush are properly installed, pull the belt forward towards the brush, and make sure that the brush spins while you're pulling the belt. If the brush does not spin, then either the belt is pinched underneath of the roller brush, or the brush is bad / installed incorrectly. Make sure that the brush spins freely before reinstalling the bottom the plate, otherwise the belt will burn and break again as soon as you turn on the vacuum.
Step 7. Reinstall the bottom plate, and screw down the four screws. Now you can turn the vacuum on, and make sure that the brush is spinning. If the brush is not spinning, repeat the steps above to make sure that the belt and brush were put in correctly.
That should fix your problem. Ideally you should change your belt at least once a year. Even if the belt doesn't break, it will stretch out. When the belt is stretched out, it will not pick up as well as a new belt will.
If you have any problems, or questions about how to do it, please feel free to use the Clarification Request here on the Fixya repair page, and I'll be more then happy to answer any follow questions for you.
Here's a link to the owners manual for your model that will also give you diagrammed pictures of how to replace your belt.
http://www.hoover.com/pdfs/manuals/U5140900.pdf
If you found this repair helpful, please be sure to rate this repair helpful by clicking the thumbs up icons. This small token of appreciation keeps Fixya repair experts continue posting free repairs to help the community. Thank you very much, that's greatly appreciated.
Chris J.
GoVacuum
Posted on Apr 07, 2010
Brush stopped spinning and is sparking
Hi there Amanda, it's Jack at Dyson.
Unfortunately it sounds like the shoelace jamming the brush bar may have caused damage to the cleaner head. It's probably best if you can give our freephone Helpline a call so we can take some further details. If your machine is within our 5-year guarantee period, our experts can confirm if we're able to replace the cleaner head for you.
You can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
We'll look forward to speaking with you.
Mar 19, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Dc24 has started sparking
Hi Amanda, it's Jack at Dyson.
Mar 19, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dirt devil wont turn on
first thing to do is to look in the dirt container for what masy have been sucked up.
Nov 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
Help! I got a shoelace hung in my Dyson, turned it off pulled shoe lace out, now the brushes will not turn. There was no smell, I thought it was really nothing. Dyson sent me a new head and still don't...
Hi William, it's Jack at Dyson.
I've just replied to you via the email address you've supplied. I'll look forward to hearing back from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Sep 14, 2013 | Dyson Dc 25 Animal Upright Bagless Vacuum...
Reset button ON DC25I
Dyson created a good vacuum cleaner but it seems odd that this problem of sucking a shoelace would disable your vacuum cleaner. I even replaced the head. PLUS they want 150 dollars to fix. Come on, if this where Dyson is going, to create something that's going to cost 100's of dollars to fix, then DO NOT BUY DYSON! They did send me a new head but my head still won't turn even after resetting the electrical button. I BET it's an easy fix. Lucky all we have is hardwood floors but frankly it would be hard for me to suggest to someone else that Dyson is the best. A product is ONLY as good as the warranty behind the product.
Apr 25, 2013 | Dyson DC25 All Floors Bagless Upright...
Beater bar stopped after sucking up shoe lace
Hi choward40,
Yah, vacuums don't particularly care for shoelaces! :>)
Did you get the shoelace taken out of the beater brush?
Did the shoelace go all the way into the machine?
Please reply back. Thanks,
Handie Andie
Apr 16, 2011 | Dyson Vacuums
I ran over a shoelace and now the brush won't rotate. I have the healthy home bagless
Shoelace is probably lodged in the roller somewhere...you'll need to take the cover off as if you were changing the belt and look at the roller to see where the lace is and remove it ...if you don't remove it n try to run the lace out then you risk burning up a belt
Jan 22, 2011 | Bissell Healthy Home HEPA Bagless Upright...
Model #169171 not sucking up dirt
I have the same problem. When I pull the hose out it seems to have plenty of sucking power though. I dont know what the problem is and why it wont pick up much from the carpet. The stuff it does pick up never seems to make it into the canister either.
Jan 23, 2010 | Kenmore 85930 PowerSpin Deluxe Upright...
Jan 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
87 people viewed this question
Top Simplicity Vacuums Experts
Tally Girl
Tally Girl
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
