USB flash drive problems
Computer manager it just says DISK 1 Removable (J) No Media. I have already tried to change the letter path from D to J and it still didn't help.
  • Jan-Burger Van Wyk Jan 08, 2013
    Hi Brian, thank you very much for your help, but I am unfortunately still stuck after all of this! First of all I when I go to universal bus controllers it doesn't give me any errors or yellow or red exclamation or question marks, so I cannot choose to update /reinstall the drivers. When I did get to an option to update it just said that it is up to date. Also when I go to disk management, the usb drive is listed seperately from all the other drives and it states that it has no media and is removable disk. I don't get the same options when I right click on this, so I don't have the option of going to tools. I think the problem might be with my laptop, because this usb drive works perfectly on any other computer. I have a brand new HP ProBook 657b. Any other external harddrive I plug in does work, but no usb flash drives. Any help will be very greatful!
  • 27,725 Answers
Also you might need to do this Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7
Posted on Jan 09, 2013
When insert mini sd 2 gig to computer it massage :please insert a disk to drive ... please help me
Insert your mini sd into the USB port.
  • Click Start/ My computer/Manage/Disk Management
  • Right click on the partition corresponding to your removable media and select Change Drive Letter and Paths
  • Finally change the drive letter (like W: or Y:). It is very unusual for Windows to use these letters.
Oct 07, 2013 | Electronics - Others
My 8gb wont open it say incorrect function and it does not allow me to format
insert your flash disk into your computer right click on my computer on the desktop. Go to "Manage". On the left side of the Computer Management window click on Disk Management (under Storage). Then right click on the name of your flash drive (typically called the manufacturer's name, default, or removable media). Click on change drive letter and paths. Then click Change, and choose a drive letter that is not currently in use, any letter . Press OK twice to return to the computer management window, press the X, and you should be back at the desktop and able to access your flash drive
May 18, 2012 | Kingston 8GB Data Traveler - 108:...
Getting "update.exe - No disk"
This issue occurs when all the following conditions are true:
• You have a removable drive configured as drive letter C.
• You do not have a removable disk in the removable disk drive.
To resolve the issue, use one of the following methods:
Change the drive letter assignment for the removable drive to a letter other than C.
To change the drive letter assignments in Windows 7, follow these steps:
1. Log on to the computer as Administrator.
2. Insert a disk in the removable drive.
3. Click Start, right-click on Computer, and then click Manage.
4. Click Disk Management.
5. Right-click the partition, logical drive, or volume that you want to change, and then click Change Drive Letter and Paths.
6. Click the removable drive, click it, click Change, click the drive letter that you want to use, and then click OK.
Feb 01, 2011 | Computers & Internet
When i insert my 4gb pendrive ,it write insert disk drive what i do/
Dee:---- Log in as Administrator account in windows or any other account with administrative privileges
Dee:---- . Insert your removable disk into the USB port.
Dee :----. Click Start, now right click on my computer and select manage
Dee:----. Now, click Disk Management
Dee:---- . Right click on your removable drive partition and select Change Drive Letter and Paths under Disk Management ( you can find your drive easily through size )
Dee:---- . Change the drive letter some other drive letter like X: or Z: which is not reserved by some other drive on windows.
Dee:-----. That's it! Done.
Thanks
Deepak Kulkarni
System,Surat
+91-9898726758.
Dec 14, 2010 | Transcend (589307) Media
Windows disco non presente exception processing message c0000013 parameters 75b1bf7c 4 75b1bf7c 75b1bf7c
Wrong removable disk/media letter in My Computer.
Go to Start / Computer management / Disk management / in there check that the first partition on the hard disk is C and none of the other partitions/removable media disks have assigned the C letter. If one of them has it (or none at all) then right click on it / Change Drive Letter and Paths... / Change / select another letter / OK .
May 23, 2010 | Microsoft Windows XP Professional SP3 Full...
When is insert my pen drive in compute then show insert a disk in drive
In order to resolve the issue, use the following methods given below:
Method 1: Insert the removable disk in the removable drive before you start your computer. But in this case, make sure that the first boot device in BIOS is not USB drive, else computer may not boot at all.
Method 2:
1. Log in as Administrator account in windows or any other account with administrative privileges
2. Insert your removable disk into the USB port.
3. Click Start, now right click on my computer and select manage
4. Now, click Disk Management
5. Right click on your removable drive partition and select Change Drive Letter and Paths under Disk Management ( you can find your drive easily through size )
6. Change the drive letter some other drive letter like X: or Z: which is not reserved by some other drive on windows.
7. That’s it! Done.
Regards,
Shrey
Oct 07, 2009 | Computers & Internet
When connected by USB cable removable hard disk does not appear in Windos Explorer. However, on other peoples PCs, the disk is visible.
your computer is probably naming it F: or something, but your PC already has a device issued to that letter.
Right-click on 'My Computer', it will open a 'Computer Management' window. On the left side, under 'Storage'.. click on 'Disk Management'. It will show some devices like your c: drive and d: drive.. does it recognize your removable hard drive?... if it does then right-click on it and choose 'Change Drive Letter'. CLick on the 'Change' button and change the drive letter to Q or X or something ...then apply it close the windows... then open Windows Explorer and see if you see your removable hard drive now.
good luck.
Sep 15, 2009 | Electronics - Others
Removable disk (usb plugged) invisible
go to disk management again and delete that drive letter wihich you add.
then check .
If still face problem then go to my computer property then hardware then device manager then unistall all usb drivers then restart computewr then connect scandisk to computer.
Thanks for using fixya.
please rate my solution if it helps.
Jul 18, 2009 | SanDisk 2GB microSD Memory Card
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
PEN DRIVE ERROR
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Feb 03, 2009 | Transcend (589307) Media
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
