Question about Dryers
Need to change capacitor on hoover vhc 180 dryer
4 Suggested Answers
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
  • 3074 Answers
SOURCE: my belt has broken on
you will need to open the dryer up:
http://www.partselect.com/dryer+open-cabinet+repair.htm
and make sure the belt is routed correctly:
http://www.applianceaid.com/images/belt-config.JPG
Posted on Jan 11, 2011
kachbibi1
  • 979 Answers
SOURCE: Hi I have a Hoover VHC 180 tumble dryer which when switched on just makes a buzzing noise. I have removed top and pushed the drum which then starts to turn. So I'm guessing I need to change the star
Yep, rhe starter capacitor is bad. Fortunately, it is an easy and cheap fix.
Posted on Jan 25, 2015
How do i get access to the motor on a hoover vhv781c tumble dryer as i need to replace the capacitor
Hoover vision hd tumble dryer VHC680F 16/10/2012 ...
? 0:19
https://www.youtube.com/watch?v=WCiQ9qc2TWk
Oct 16, 2012 - Uploaded by Ben Smith
Ben did you manage to change the capacitor? I got the same problem but I cant actually get close enough to the capacitor to replace it!.
Nov 26, 2015 | Hoover Vacuums
How do I change the heating element on a hoover vhc 691 b tumble dryer?
Many of the heating elements can be seen and changed by laying the dryer on its back...the element is usually visible from the bottom. I found the part on the link I am incuding for you. Hoover VHC 691B80 Dryer Element 2100W
Dec 15, 2014 | Hoover Dryers
How to get to motor on hoover vhc691b?
Very rare a motor fails on a hoover drier normally its the capacitor that fails. you can hear the motor humming but the drum wont rotate to proof its the capacitor turn the machine on press start listen for the motor humming open the the door of drier turn the drum by hand fast then shut the door as fast has possible then the drum should start going around . then this proves its the capacitor fault you are doing the job of the capacitor giving the motor a start .
May 16, 2014 | Hoover HDC6 Electric Dryer
My Hoover VHC 381
Unplug the machine and take the top off, check the door switch to see if it is broken or bad.
Jul 23, 2013 | Hoover Dryers
Hoover Tumble Dryer VHC 391t. Its starts and does a cycle stops to turn the other way and just stops. If you press the start button it just clicks.
The most common problem for this would be the motherboard of the system that's controlling the Hoover Tumble Dryer. You will have to either get it repaired by a professional or get a new dryer.
May 14, 2012 | Hoover VHC391 T-80 Dryer
Hoover hvc 180 not drying clothes
You will need to check the internal, as well as the external vent line for lint buildup.
Apr 28, 2012 | Hoover VHC391 T-80 Dryer
My belt has broken on my hoover vhc 392t and im not sure how to replace it
Jan 11, 2011 | Hoover Dryers
Dryers Logo
198 people viewed this question
Top Dryers Experts
