Question about Sony MHC-771 Shelf System
Which type of woofer i connect to sony mhc771 what is sony super woofer or sony active super woofer is it available on market
Can I and how do I hook a subwoofer to my Sony str-de705 receiver
It depends. You can connect an active (self-powered) sub-woofer to the STR-DE705. You can't connect a passive sub-woofer that needs power from the receiver. If the sub-woofer has its own power cord, then it's an active unit. See https://us.en.kb.sony.com/app/answers/detail/a_id/37001 for more information. You'll also need a RCA subwoofer cable. This is like a RCA audio cable but only has one plug on each end. (Using a regular audio cable may risk a short when the extra plugs hit something.) Many subwoofers will come with the audio cable. If you do need one, they are available at most places that sell cables, including Amazon.com .
Here is an example of an active subwoofer: https://us.en.kb.sony.com/app/answers/detail/a_id/37001 . This is the Yamaha YST-SW012.
I hope this helps.
Mar 15, 2016 | Sony Audio Players & Recorders
What is a sub woofer pre-out ?
Sub-Woofer pre out is for connecting that terminal to the input terminal of any sub-woofer. The sub woofer which it should be connected must be an active type [that is, there must be independent amplifier section built it with that sub-woofer; not mearly a crossover network].
Oct 22, 2012 | Denon RC-920
I have a pair of JBL N24AW outdoor speakers. One of then has lost the woofer and I am only getting what the tweeter puts out. I think it's a 4" speaker. Can you get a replacement for this?...
Hello
Woofers of different types are available in the electronic sparepart market. Just open the woofer box, and screw out the present woofer, and check its impedence and size. Keep this speker with you as sample, go for a new one. You can bought it from most of the electronic sparepart shops. OK.
Jun 14, 2011 | JBL N24AW Main / Stereo Speaker
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
I have a sony str de 325 receiver....what sub woofer will go with it and where do you plug it into the receiver?? Thanks
You will need a powered sub, one that has a built in amp. It will also need speaker terminal type inputs. Use the B channel to send signal to the woofer. Since the audio from the B channel is full range, use the crossover on the sub to determine which frequencies you want to hear. I would start at 100Hz and go up and down from there. Use the gain to adjust the volume in relation to the other speakers. The sub volume will be affected by the master volume.
Please rate if this helpful
Apr 05, 2011 | Sony STR-DE325 Receiver
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
Eltax DR-110 Sub-woofer issue
Where have you connected the sub's leads?
Feb 26, 2008 | Audio Players & Recorders
Cables
you coudl use a single rca to a left and right rca cable. However most woofers will have a lfe single rca input on the woofer that you connect to a single rca on the receiver.
Are you sure you are not confusing the +/- on the woofer that is used to connect your speakers? ie. my woofer has the +/- so i can connect to my front speakers and my receiver to filter the low frequency sounds via the woofer.
hope this helps
smeags.
Feb 19, 2008 | Sony STR-DE575 Receiver
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
