Question about Microwave Ovens
Microwave model no.NN-C2003S beep sound has become low.Please provide remedy
Panasonic Microwave model no.NN-C2003S beep sound has become low.Please provide remedy
  • Madhav Rajadhyaksha Jan 15, 2013
    any other solution?Please let me know nearest service centre near Dadar Mumbai
  • Microwave Ovens Master
  • 9,098 Answers
Try a reset by:
- unplugging power for a minute
- plugging it back in
- setting the clock
- trying it again
If that does not fix it, see your owner's manual to see if it can be adjusted (usually not).
If you still have trouble, you should call for service.
Posted on Jan 09, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: Need door assembly diagram to
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic microwave touchpad not working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
You may instead have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs, which depends on the exact model, one of these:
NNS688BA NNS688BAS NNS688LA NNS688LAS NNS688WA NNS688WAS
Please feel free to contact me directly if you need more help.
Posted on Oct 08, 2008
SOURCE: Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
Posted on Aug 27, 2009
Testimonial: "Hi - and thanks Martin for an excellent description of the process. Perfect assistance for a handyman-challenged guy like me. Thanks Grant"
  • 178 Answers
SOURCE: Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Posted on Sep 13, 2009
Testimonial: "Thank you for replying! You really seem to know what you are talking about!"
  • 178 Answers
SOURCE: Need a users manual for a Panasonic Dimension 4
http://www.retrevo.com/samples/Microwave-manuals.html
Hope this helps!!
Posted on Sep 14, 2009
How, where can i buy a ring roller for a panasonic NN-C2003S?
Fixya is unable to suggest Panasonic parts sources.
Mar 17, 2018 | Panasonic Microwave Ovens
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
My microwave has lost its beep when it has finished its time set???
What make and model is it? Does it beep when you press other buttons, or is it always silent now? It could be the speaker if there is no sound at all. Or perhaps you accidentally set the microwave to a silent setting. Try looking in the manual or searching online for silent mode for your microwave model.
Jun 10, 2015 | Panasonic NN-P794SF Microwave Oven
Where can I get the membrane and digital unit board for model NN-C2003S? Please provide the website.
If you can tolerate the time and cost of international shipping, contact www.fixyourboard.com
They repaired my 20-year old wall oven control board and shipped it back to me with 1 year warranty. Works like new.
Jan 19, 2018 | Microwave Ovens
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
Inside the NN-C2003S microwave on the right hand side is a paper like material that has deteriorated (90 mm long and 30mm high) and exposed an opening. Where can I buy a replacement cover or can I use...
It's made of milar from memory. 4 years ago I needed a new one as well as a magnetron and the ceramic tray, and even though I live in Sydney, LCS Electronics in Western Australia were by far the cheapest for the parts. Back then I think the milar was around $8.
Apr 01, 2011 | Panasonic NN-T888S Convection/Microwave...
I have a Panasonic NN-C2003S microwave/convection oven that won't heat anything under micropower mode and on countdown cuts out when it gets to 8 sec. It is working on the convection mode. Could someone...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
This is a job for a professional.
Hope that helps.
Jan 04, 2011 | Microwave Ovens
Microwave Ovens Logo
105 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
