Question about HP Compaq Presario SR1830NX PC Desktop
Black screen cant display anything on the monitor
  • ebjerick2
    ebjerick2 Jan 08, 2013
    The power is ok but it cant display anything on the monitor even the BIOS... cant be seen
  • HP Master
  • 2,386 Answers
Check the power of the computer
Posted on Jan 08, 2013
Screen won't come on my asus laptop.
Laptop screen won't turn on, but works with external monitor ...
www.tomsguide.com/.../laptop-screen-turn-works-external-monitor.html
Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
ASUS laptop screen won't display anything - Tom's Guide
www.tomsguide.com/answers/id.../asus-laptop-screen-display.html
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
Asus laptop black screen problem - YouTube
? 7:52
https://www.youtube.com/watch?v=gRQgN5AT3a0
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
Dec 13, 2015 | ASUS Computers & Internet
Black screen
first check your display in monitor with the help of vga cable attach your laptop in the monitor,if display comes in the monitor it means your screen faulty .or if display cant seen on monitor it means there is an fault on MOTHERBOARDS BGA CHIP.
Jan 29, 2014 | Lifetime Acer Aspire 4736Z Replacement...
What do u do when ur mac book's screen is black and u cant see anything but its still on
Connect an external monitor that has an Apple monitor connector. See if you get video. If you do, your display is bad.
Nov 11, 2010 | Computers & Internet
Screen is black..will not display anything. Any
You provided very little information, so I'll try to answer:
I assume you turned on the comptuer and it seems to be working-you didn't say.
I assume it used to display something-you didn't say.
Hook it up to an external monitor. Can you see something? If so, one of two things are wrong: Your LCD screen has gone bad OR you need to hit the Fn/Special function key combo that moves the display from your LCD to an external monitor.
If none of these solves the problem, then your video card has gone south on you.
Jan 23, 2010 | Toshiba Computers & Internet
Black screen
Don't let the computer turn the monitor off. Go into control panel and click on power option. don't let the computer turn anything off and disable hibernation if on. go to screen saver and have it come on in about 30 mins.
May 27, 2009 | ViewSonic VX2235wm LCD Monitor
Samsung laptop black screen
Sounds like a loose connection between your mainboard, inverter or LCD. Try to connect an external monitor and see if the display appears to the external monitor. If a display appears on the external monitor, you need a qualified technician to check your laptop. I fixed 3 laptops with that same symptoms, 1 has loose connector, 1 has ground problem and the other is an inverter.
Apr 09, 2009 | Intel Motherboard
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Cant see anything but white screen after bootup
Plug in an external monitor and use the F key with the FN to toggle between lcd and external monitor. On my laptops It is the FN and F5. If the external monitor works the problem is the the inverter board, the flex ribbon cable or the LCD. If the external monitor is also messed up then the problem is probably the video card/ motherboard.
May 14, 2008 | Sony VAIO VGC-LS30E 1.73GHz Pentium Dual...
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
My monitor remains black
well your screens broken mate the only thing you can do is get a new one
Sep 30, 2006 | Amptron CMV-922D 19" Monitor
HP Compaq Presario SR1830NX PC Desktop Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
