Question about Toshiba 27A34 27" TV
PHILIPS 42PFL5603D/12 Cant shut down TV, with remote control, with power button on side. The lamp on TV is blinking when pressing buttons on remote control, but nothing is happening with TV, it cant be shut down, only taking out main power cord from wall. please help
bkvinr
  • 76 Answers
SOURCE: Toshiba TV 35A44 Volume Issue
During the volume increases problem takes place suddenly remove battery from remote control. Check the problem continuous. If it is there the problem is tv front panel volumeup switch is malfunction or failure. Change the switch problem solved.
Posted on Aug 24, 2007
  • 298 Answers
SOURCE: Toshiba (Model : 36A43) - volume goes down automatically
Try removing the batteries from the remote. Then adjust the volume from the tv panel. If the problem is resolved, then it sounds like you may have a stuck remote button.
Posted on Jun 18, 2008
jerryg50
  • 1673 Answers
SOURCE: Toshiba TV - 29 inch - model 2990 XEL
This may be a fault with the firmware (internal software for the uPC), or it may be a failure in the circuit area or chip that generates the fonts and characters for the menu display.
You will have to send the set for factory level service if this is the case. If you give the set to an independent service center, they may have to send the set out on your behalf.
I would be careful to not invest too much money in to servicing a TV of this generation.
Jerry G.
Posted on Jul 12, 2008
  • 51 Answers
SOURCE: Time Warner Remote Codes
find your remote instuctions and it will say in them. dont follow the tv stuff.
Posted on Feb 11, 2009
SOURCE: TV STUCK IN "DEMO MODE"
I had the same problem with my TV, This is the way i fixed the problem i took a hammer and banged on the menu button a few times and know the tv works great!!!. Little weird huh:)
Posted on Jun 16, 2009
What is the code for the philips remote for a symphonic tv
Hello
There is no specific code list given to this Philips remote control model. Yet you can find out the stored code of your device, whichever it may be, by the following method.
Turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the SETUP button until the red
indicator remains on, then release SETUP button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press and release the numeric button (0-9)
corresponding to desired Manufacturer (see table on
code list sheet). The red indicator blinks off once.
Note, pressing "0" performs a full library search same
as normal Code Search Method on previous page.
5. Press the CHANNEL UP button ((or POWER or
PLAY (VCR only)) repeatedly until the device to be
controlled changes channel. The red indicator blinks
off with each button press. If you accidentally
overshoot the code required, press the CHANNEL
DOWN button to backtrack through the library until
the device changes channel. Pressing CHANNEL
UP changes direction to forward again.
6. Press and release MUTE to install the code.
Brand Search Method entry is now complete.
Note: When all codes under a Brand have been searched
the red indicator flashes rapidly for 3 seconds.
OK.
Feb 23, 2011 | Philips SRU2103S-27 Remote Control
How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • Dec 04, 2010 | Philips Televison & Video
    I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
    I suggest you try these steps..
    1.Turn the television set on by pressing the "Power" button on the set.
    2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
    3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
    4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
    5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
    I hope this helps...
    Jun 10, 2010 | Philips Magnavox Learning Universal Remote
    I lost my one for all codes sheet need help please i have a sylvania tv
    press and release the tv button , then press and hold down the set button . the light will blink twice ,now enter code991 ,light will blink twice again. now aim remote at tv and keep pressing tv and power buttons untill your tv shuts off. now try to turn tv on
    Oct 11, 2009 | Universal Remote Control Remote Control
    Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
    Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
    Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
    Code for my philips remote P435S
    http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
    This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
    Programming with Code Search
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
    3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
    4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
    Hope this helps :)
    Jun 21, 2008 | Philips PM435S Remote Control
    Philips universal rermote codes
    Hope this helps :)
    Jun 16, 2008 | Philips Televison & Video
    Help
    Hope this helps :)
    May 18, 2008 | Philips Universal PH301S Remote Control
    I changed batteries in my remote and i cant figure out how to reprogram it
    Hope this helps :)
    May 13, 2008 | Philips Universal PH301S Remote Control
    32PFL5232D/37
    The code is 0081 and this is how you do it.
    '4 digit' or 'Brand Set' method
    1. Turn on your TV.
    2. Press TV on your Sky remote control.
    3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
    4. Press TV on your Sky remote control again.
    5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
    If the light blinks once only, re check the code for your TV and start again at step 1.
    6. Press the on/off button (power-top right button on your Sky remote control).
    If your TV switched off, press select . The light on the Sky remote control blinks twice.
    If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
    If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
    7. Press TV guide .
    If you see the TV Guide screen, the remote control setup process is complete.
    If you did not see the TV Guide, you must now set the TV Guide function as follows:
    8. Press TV on your Sky remote control.
    9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
    Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
    Toshiba 27A34 27" TV Logo
    142 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
