Cuts out at 50 but used to heat right upto 90
    Genius:
  • 1,669 Answers
It sounds like the switch contacts are worn out...change the switch!
Posted on Jan 10, 2013
I have a TGB Akross 50 cc.Engine cuts out when going down hill. Engine sluggish down low. How do I fix this?
not enough exhaust flow will cause it to be sluggish -- open the exhaust up so it breathes.
Feb 26, 2015 | TGB Atlantis City 50 2T Motorcycles
Refill manual gearbox with what oil?
gearbox oil grade SX75W/90 make is upto you
Mar 28, 2014 | 1999 Kia Sportage
Starts ok revs ok for a short time then cuts out
The problem your having is your not geting enough fuel into the engine. reconditioned equipment will have some ware on it causing it break down faster.
If your machine manual tells you to use 50:1 ratio use 32:1-40:1 because 50:1 has less oil in it to lubercate engine than 32:-40:1 new/recondition equipment when run older equipment from the 90's 32:1-40:1 fuel ratio will run better and last longer. You may have to adjust mixing screws on carburator for the 32:1-40:1 ratio, but you notice better performance out of your trimmer and it will may start faster.
Oct 05, 2011 | Ryobi Factory-Reconditioned 26cc 22" Gas...
When the AC cuts off the blower fan runs for 90 more seconds, I have a Honeywell RTH8500D thermostat, I really don't like that, I live in Texas where the AC runs all the time.
Hello, usually tne blower runs longer to get all the cold air out of the air ducts, same thing happens in heating evcept it's warm air. You can change the blower timing by adjusting it on the integrated control board, it will say blower off timeing, this is what you use to adjust the blower timing. However, 90 sec is the least the blower will run on most furnaces.
May 24, 2011 | Heating & Cooling
Vehicle overheats after runnig only a few miles.what could cause this?
Low antifreeze level
Coolant should be mixed 50/50
water pump not pumping. (and will also be leaking 90% of the time)
Cooling fans not working
Jan 12, 2011 | 1994 Pontiac Grand Prix
I followed the haynes manual to tighten up the head bolts on my 1995 mitsubishi pajero 2.8td exceed, supposedly, tighten up all uniformly to 100NM, back all the bolts off, tighten again to 50 NM, tighten...
Cylinder head
Renew bolts Yes
Stage 1 Tighten 50 Nm
Stage 2 Tighten 100 Nm
Stage 3 Slacken off 360°
Stage 4 Tighten 50 Nm
Stage 5 Tighten 90°
Stage 6 Tighten 90°
Stage 7 Tighten M8=24 Nm
Feb 12, 2010 | 1995 Mitsubishi Diamante
How to increase channels on Old BPL TV
hello sir, iam having a BPL tv,with 100 channels,,,the problem is i cnt watch around 50 channels,even the cable operator provides 100 +. there are three bands coming while tuning,L,H and U.am getting channel during L,H,but when it goes to U,then everything is blank...U(UHF) is starting from around 55,so all channels are blank upto 99. could you please help me???
Sep 11, 2009 | Televison & Video
2002 rander edge
Thats cause the truck is governed at 90 mph it cuts off the picks right up at 85mph. But most trucks cut of at 100mph
May 20, 2009 | 2002 Ford Ranger Regular Cab
My atv doesnt rev up
I have a Aeon Cobra Quad 100S, after 2 years of not being used I finally got it going. I cleaned out the carb, changed spark plug, and now ticks over all day long, but as soon as you apply the throttle it cuts out. Please answer in laymans terms.
Mar 31, 2009 | Polaris ATV
Problem connecting Onkyo Amplifier to Bose Accoustimass speaker system
This is probably correct as modern equipment uses electronic volume controls rather than potential dividers the range is normally biased towards the bottom end so there is lots of the range that is quiet and a smaller part that is loud.
Unless you find that at the top of the volume range the system does not seem to be loud then it is probably correct. It is not uncommon for modern equipment to clip at 80 / 90% of the volume range. Where as old style equipment with volume pots used to clip at arround 30% of the volume range as it gave the apperance there was loads of extra volume available. In fact all that happened if you turned it up louder was it clipped more and more.
Regards,
Andrew
Sep 17, 2008 | Bose Acoustimass 16 Speaker
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
