Question about Fagor Ovens
Fagor 6H-230 X - Timer keeps resetting itself
Fagor 6H-230 X - Oven will not work if the timer is not set. A week ago it would let me set the timer allowing the oven to work but would always reset itself in the middle of the night (never at the same time though). Now it won't let me set it at all, just keeps going back to 00:00.
5 Suggested Answers
SOURCE: Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
Posted on Jan 20, 2008
SOURCE: FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Posted on Sep 14, 2007
  • 22 Answers
SOURCE: oven won't work - its a timer problem how do I reset the timer?
I believe the control's child lock function is enabled. To disable it, press and hold the cancel key (will have small padlock icon under the word "cancel"). That should clear the condition.
Posted on Apr 25, 2009
  • 8 Answers
SOURCE: Electrolux oven won't come on
It appears that the "return to manual" button has to be reset
Posted on Sep 02, 2009
My St George Electric oven keeps turning itself off.
Possible checking the power switch, the timer control unit and also if there is any power trip in the circuit.
The most possible chance could be related to the timer unit, so reset the timer control , try setting to higher levels and see if the power holds on.
Jul 09, 2015 | Ovens
How to set timer for my fagor oven
www.fagoramerica.com/my_fagor/user_manuals
Jul 27, 2014 | Ovens
Setting clock on fagor 6h-230 x
Fagor appear to be a poor quality brand of oven. I also cannot get the timer to turn on the oven. I am going to find out how to bypass it as I dont want to wasre more money on such bad quality machinery. T P Kennedy
Mar 30, 2014 | Fagor Ovens
I have a new control panel that was just put in 2 weeks ago. I pressed the button start to long & the "Loc" came up on the display & it won't go off no matter what button I push. I've...
Did you replace the panel yourself? If it was a repairman it should be under warranty. Anyway I would think that after the supply has been turned off overnight the timer would reset itself. If that doesn't work and you don't want to keep mucking around with control panels and you can do without the electronic clock the control panel can be easily bypassed by a repairman. This will then enable manual oven operation.
Feb 16, 2011 | Ovens
Kenmore Classic Wall Oven Model # C97047191-2 Serial # NF91008197 nothing on it works (was fine last night) checked the 3 fuses under the stove and the breaker is good on the electrical panel. Is there...
I think that the ONLY problem is to set properly the TIMER; The TIMER is set OFF and the OVEN does not work; try to push and/or release the timer buttons and it will work. I have the same problem and it is very unfortunate that I have no manuals.....
Oct 05, 2010 | Ovens
Bottom oven switched off when setting timer. Can't get it to go on again. Oven is only a few weeks old.
Switch off from mains, reset the clock (not the timer) and it should work ok
Sep 04, 2010 | Siemens Ovens
Where can i get a manual for a built in teba fan oven. It has reset itself and the timer switches off after 2 minutes and I cannot reset to not use the timer so cannot cook anything in the oven.
Try pressing the stop/cancel button, this should clear the error, if this does not work unplug for 5 minutes and then plug back up , this should clear the display and the oven should work.
Nov 14, 2009 | Ovens
Aug 25, 2009 | Electrolux EW30EW65SS Stainless Steel...
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
Ovens Logo
222 people viewed this question
Top Fagor Ovens Experts
Dan Webster
Dan Webster
ray gallant
Bill Boyd
Are you a Fagor Oven Expert? Answer questions, earn points and help others
