Question about Amana Refrigerators
Have a side by side amana model #ssd25tw. Water dispenser won't work and lights in fridge don't work? Fuse? Loose wire? Can't figure it out.
SOURCE: amana side by side ice dispenser leaking water
icemaker wont dump ice
Posted on Jun 19, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
  • 219 Answers
SOURCE: amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Posted on Mar 19, 2009
SOURCE: maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Posted on Apr 09, 2009
rick_chong99
SOURCE: Water dispenser not working
I have a Hitachi R-M800GM.
When i operate the water dispenser, water flows out from the dispenser [not strong flow]. There is also water flowing out at the bottom of the freezer door [hinge area]
I think the line running inside the freezer door may have come loose? If so, how to reattach it? Do u have any layout drawings of how the hose is being connected.
Please help.
Thanks,
Rick
Posted on Dec 11, 2009
Refrigerator Amana model ASD2620HRW ice/water panel no longer working
Request the wiring diagram directly from Amana and start troubleshooting.
Mar 07, 2018 | Amana Refrigerators
Water and ice dispenser don't work
This is a pretty common problem...
Try unplugging the fridge for 30+ seconds. If the display doesn't light up after you plug it back in then the control board is dead. It's going to need to be replaced.
If you know the model # of your fridge you can search for a replacement part here:
http://www.searspartsdirect.com/partsdirect/index.action
Dec 31, 2012 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have an Amana refrigerator model#SRD22S5W. Neither the ice maker nor water dispenser get water. I have confirmed that water is getting to the fridge but it seems the switches are not working opening to...
There is a solenoid in the back where the water line tie in. If the solenoid is bad, no water will get to either. As someone is trying to dispense water, hold a metal object (like a screwdriver) to the top of the round part of the solenoid. If there is some magnetic resistance, then the solenoid is good. If not, replace it.
May 08, 2011 | Amana 25.8 cu. ft. Side-by-Side...
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
May 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Please help.
Thanks,
Rick
May 31, 2009 | Amana ARS2464B Side by Side Refrigerator
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
32 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
