I am using Ricoh C2030 multifunctioner in windows 7 OS. Whenever i am trying to scan the error msg occuring "36851 no response from the scanner". I can detect the scanner from my laptop and Acrobat Im
  • Office Equip... Master
  • 2,385 Answers
It needs to install the drivers of the scanner
Posted on Jan 08, 2013
2 Suggested Answers
raja007007
  • 124 Answers
SOURCE: Error 36851: No response from scanner" ricoh
You have to just replace your cartridges.It show the error because the cartridge has a problem.
Posted on Feb 07, 2011
I installed the new Canon LiDE 110 scanner drivers. When I click on the Scan button, it gives the error msg: Cannot Communicate with scanner. Cable may be disconnected. Scanner driver will be closed
I was getting that same error message, every second time I tried to scan something. I had the scanner connected to a USB 3.0 jack. I switched to USB 2.0 jack, and the problem was solved.
Oct 06, 2012 | Canon CanoScan LiDE100 Flatbed Scanner
Gestetner Aficio MP 1600 was connected to my System and I use it as photocopier, scanner and printer. The machine's Drum was changed of recent and it has failed to scan any of my documents. However, I...
Hello!
Changing the Drum does not affect the scanner settings.
You can print because your PC (computer) can see your machine but for scanner is the oposit. The machine must see your PC.
I think that in this machine you have an SD card with the scanner funtion. Try to take it off and then put it on again. (the SD card is on its side. In the controller box)
If you still have any doubt reply to me.
Aug 01, 2011 | Ricoh Aficio 250 Copier
Dear kishorkamble,
We fixed this error, which happened in another model (Aficio MP-5500), by configuring two options:
1. Activating SNMP protocol. Menu Configuration -> Network -> IPv4
2. Activating RSH/RCP protocol. Menu Configuration -> Network -> SNMP
I hope it may be useful.
Yours sincerely,
Bruno Coutinho
Feb 07, 2011 | Ricoh Aficio 2018D All-In-One Laser...
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Scanner Does Work
Kindly check the below links with respect to your operating system to fix the problem
Windows XP
Windows Vista
Windows 7
Mac OS X
Regards,
Riztech
May 07, 2010 | HP Photosmart 3210 Printer
I can not use the scanner, Ricoh Aficio 1515. I alredy instal the twain driver ver.3 from the original cd, when I open the function palete, looks like its conected with the machine, but when I try to...
Visit the Ricoh download site and download the latest driver. This will ask you if you wish to overwrite, say yes. Hopefully this will replace the corrupt file.
Aug 01, 2008 | Ricoh Office Equipment & Supplies
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
878 people viewed this question
jasbo
jasbo
