Question about Bosch Washing Machines
Cannot remove filter from my bosch wfb 4001 washing machine
I can unscrew the cap, but only the cap itself comes off - how do I get the filter out? the washing machine does not drain so I'm trying to figure out wether something is stuck in the filter or if its a problem with the pump? any suggestions much appreciated!
  • 1 more comment
  • Stef_ski Jan 08, 2013
    I have already looked online at videos of people removing the filter - they unscrew the black cap and then remove - there is a white plastic cylinder attached to the cap (assume filter?), however for me only the black cap comes off. has the cap snapped off? or is there some other way of getting the filter out?
  • Stef_ski Jan 09, 2013
    Solved!
    just posting this in case anyone else has thsi problem. So....turns out the cap had become detached from the rest of the filter. Two flat-head screwdrivers used to prise out the filter. As suspsected a few things blocking the pump so removed them, gave the filter a good clean, reattached the cap to the filter and reinserted. I ran the machine on a quick wash and it drained fine.
3 Suggested Answers
SOURCE: Bosch Model WFB 1605 washing Machine
Hi
I have a user manual - swedish, Suomi, Norwidian and danish
Posted on Jan 21, 2010
barkencoa
  • 3463 Answers
SOURCE: unable to unscrew cap on filter on washing machine
You should be unscrewing anti-clockwise to remove it, if it will not come out, then there is probably somethiung stuck in the filter preventing it from pulling out.
Try moving it from side to side as you are unscrewing and pulling.
Posted on Mar 17, 2010
Bosch wfb 4001
Remove the discharge hose from underneath and check for accumulation of debris. A partially clogged hose could result in leaks
Apr 15, 2014 | Bosch Washing Machines
Bosch WFB 2005 Pump Cover Stuck
You can replace the pump and not have to buy a new machine.
May 19, 2012 | Washing Machines
I was wondering if you knew were i could get a new door for a bosch wfb 4001 front loader washing machine
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
May 28, 2011 | Washing Machines
Unable to unscrew cap on filter on washing machine
Mar 17, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Washing machine WFB 4001
well, seems to me that you are using too much juice for the circuit, which implies a SERIOUS issue with the machine. perhaps the motor is locked, or something in control panel is shorted out?
Feb 27, 2008 | Washing Machines
Bosch WFF1201
At the bottom of the machine on the front, there is a plastic cover (remove by turning the plastic screws a quarter turn anti-clockwise and pull off cover). The filter is behind this cover on the left hand side. It is unscrewed by hand anti-clockwise. Tucked into the plastic cover, you should also find the spanner to adjust the feet on the washing machine. good luck and rate me....
Feb 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFB 1605 washing machine
i am so upset with my fancy $1100 plus washer that doesn't work that my husband wants to cart it to the dump
Jan 31, 2008 | Bosch WFMC 3200 Front Load Washer
Owners manual for washing machine
i am not able to open the front door of my BOSCH WFB 201 Wahing Machine, please help
Dec 09, 2007 | Washing Machines
Washing Machines Logo
59 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
