Question about Kenmore Refrigerators
How to remove front cover on water and ice dispenser mod.106.57267791 refrigerator
Cover part no. 2194592n
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
SOURCE: Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
Posted on Sep 23, 2008
SOURCE: replacing water fitting assembly
Water dispenser continues to run too long after removing glass on Kenmore Elite Mod #52603100
Posted on Nov 09, 2008
peyton32034
  • 410 Answers
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Posted on Feb 18, 2009
aborcass
  • 2651 Answers
SOURCE: I need to replace the water line tubing in the
the front dispensor panel can be removed by lookin under the panel you see too little spaces in which ti insert a screw driver,by pushing down on the top, you cantwist the screwdriver in the opening eleasing the tabs, and simply lifting off the top tabs, dependingon model you may need to un plug a wire or 2.. the tubing should be able to be removed be releasing the connector undeer the door and simply refeeding the new hose back into unit
Posted on Jan 27, 2010
I have a kenmore side by side mod 10657577790. icemaker appears to cycle but does not produce ice. i suspect water not filling tray. we lost water in the whole house for 24 hours and i think thats when the...
Hello;
My name is Peter. I am a retired field service refrigeration technician.
First, If your water dispenser is working, is the water flow strong?
If not, when you lost your water supply, the water supply valve may have become plugged.
You need a water supply of 65 PSI to fill the ice maker.
1.) Check the water pressure - With a measuring cup - run the water from your water dispenser. You should get 15 ounces of water in 8 seconds. If not then you have a plugged water supply valve.
2.) Ice maker frozen fill tube - At times the ice maker fill tube can freeze up. Inspect the fill tube and defrost with a hair dryer.
3.) Start Jump the ice maker - You will need a short piece of 16 gage wire or so, approximately 4" long, with 1.2" striped bare wire at each end.
a.) There is a plastic cover on the front of your ice maker. The cover just pops off. With a butter knife pop off the front cover.
You will see the Control Module.
25604602-imv3tze4snahc4os1l3biiwf-2-0.jpg b.) In the lower left hand corner, you will see two holes 'T' & 'H'.
While holding the freezer door switch in, insert the jumper into these holes. After 8 seconds remove the jumper still holding the light switch in.
Is there vibration?
Is the gap in the center of the gear broken?
You may have a burned out circuit or motor, or broken gearing.
25604602-imv3tze4snahc4os1l3biiwf-2-2.jpg This component is replaceable. You need to remove three face screws.
P/N: Substitution: W10190935 Cost: $110.00 (Sears)
A New Ice Maker P/N Part #: 4317943 Cost: $110.00.
Suggestion: Go into eBay, plug in the part number. You can get a new ice maker for $40.00.
4.) Bad ice maker solenoid valve. In the back lower right hand corner you have a dual solenoid valve. The smaller diameter tubing is your ice maker.
25604602-imv3tze4snahc4os1l3biiwf-2-5.jpg Substitution: 2188542 Cost: $67.00
Check the solenoid valve: Unplug the refrigerator. Disconnect the contacts on the green solenoid. Set you multi-meter to the lowest Ohms. You should get a reading across the two contacts of '0' if the solenoid is good.
Mar 24, 2015 | Kenmore Refrigerators
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Replacing water fitting assembly
water dispenser continues to run too long after removing glass
Oct 23, 2008 | Refrigerators
Front Cover to Ice/water dispenser
YOU WILL FIND TWO PHILLIPS SCREWS UNDER THE FRONT PANEL AT THE BOTTOM YOU NEED TO BEND DOWN TO SEE THEM.IT THEY ARE NOT THERE THEN YOU WILL NEED TO REMOVE THE ENTIRE DOOR LINER ITS BEST YOU GET THE HELP OF A TECH.LET ME NO IF YOU NEED FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool ED2FHEXN Side by Side...
May 22, 2008 | Kenmore 53542 / 53544 Side by Side...
Kitchenaid refrigerator in door water/ice dispensor
Look here.
http://www.fixya.com/support/t219770-kitchenaid_superba_kscs25fkss00
Jan 07, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
