Dell adapter not cme power wat prblm tell any one
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Jan 08, 2013
Inspiron mini fail to power on
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Mar 21, 2013 | Dell Inspiron Mini 10 Notebook
Phone will not charge battery from any source, ac adapter or dc adapter.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Aug 04, 2012 | HTC HD2 Smartphone
Ac adapter problem with dell inspiron 1545
TRy to remove the battery, then power the laptop on with only the ac power adapter inserted. if it powers, then your adapter is ok, and insert battery while its on, battery charging should start. otherwise, you could be having a problem with your charging system.
Regards
Apr 19, 2010 | Dell Inspiron 1545 Notebook
No connectivity for wireless usb adapter
could mean that you dont have the proper driver for your current Dell 1450 (D1450U) Wireless Adapter What operating system are you running I would be happy to find the driver for you.
Jan 03, 2010 | Dell 1450 (D1450U) Wireless Adapter
Latitude d520 will not recognize power adapter
I have heard about this problem with a number of Dell laptops, including the Inspiron models. The problem is that the connector for the power port may have been loosened after many years of use. This may require service from Dell on the motherboard.
Jan 15, 2009 | Dell Latitude D520 Notebook
Camera not supporting
the problem is with a chanel cam of the flex cable its the part that connects the keypad and camera to the lcd u need to chnage it!!
plz do rate this post
Nov 04, 2008 | Nokia 3250 Cellular Phone
D600 doesn't recognize power supply
n3sjh
Sorry to hear that you are having trouble charging your D600. In regards to the message that you are getting it most likely just a warning to make sure you plug the proper rated AC Adapter into the system. To my under standing there is no why for the noteboook to know if you are plugging in an AC Adapter that is not from Dell. However the notebook can tell if the power out is not right. So it may not accept the charge as a safety thing to keep you from frying the notebook.
Now if your original adapter is not working but you still have it this is good because you will need to get info off it. The important part is the output voltage and amps. The info has to match the info of the one that you are trying to use, if it does not the adapter will not work. The other thing is to look at is the WATs is needs to be the same or higher. It can not be lower or you will not enough power.
So in most cases if you are trying to use another adapter from other notebook it may not work. Note this is not a Dell thing, all the manufactures do this. Granted there may be an adapter that works for several model but they are usually in the same series.
Now if you can not use the original adapter then you can get a non Dell adapter. There is several 3rd party adapters out there you just need to make sure that it is made to support your system. Most of you big chain stores carry them. Like I mentioned above different notebooks have different power requirement. The down side to this is since they are made for serveral different models they usually cost a lot. However in regards to Dell's systems most of time you can get a better deal by getting a replacement from them.
Let me know if you have any more problems and/or questions regarding this issue.
Issken
Sep 30, 2008 | Dell Latitude D600 Notebook
Dell D620 power problem
sah_rose
Sorry to hear that you are having trouble with the AC Adapter on your D620. Now I have not heard the part where the light goes out when the AC Adapter is plugged in before. This maybe a sign of a short some where in he system. So this could be a problem wih the AC Adapter or the motherboard. Hopefully it is just with the AC Adapter. If you know someone with a D620 you may want to try there adapter on your system to see what happens. Also you can try the generic ones as well but you need to make sure that it will work with the D620. Mostly the issue is with the AC Adpater going bad but there is a chance that it could be the motherboard.
Now the D620's have not been out for very long so you might want to contact Dell's support to see if your system is still under warranty. If it is they will send you an AC Adapter and have the motherboard fixed if needed.
If you have any more question and/or problems let me know.
Issken
Sep 09, 2008 | Dell Latitude D620 Notebook
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
