Question about Yamaha RX-V571 Home theater receiver with 3D-ready HDMI switching
WHERE IS THE AUDIO OUTPUT WHEN USING COMPONENT CABLES ON A YAMAHA RX-V571 RECEIVER
I HAVE CONNECTED THE COMPONENT OUTPUT FROM MY CABLE BOX AND AUDIO BUT WHEN I CONNECT THE OUTPUT FROM RECEIVER TO MY DVD RECORDER I GET PICTURE BUT NO SOUND RECORDED
  • robert frontera Jan 11, 2013
    i found out on my receiver that in order to get audio out from the input you have to go to the option button on the remote and active each audio input that you are using. this solved the problem with audio output.
    Genius:
  • Yamaha Master
  • 1,054 Answers
How are you hooking up the receiver to the dvd recorder? Component connections are only going to carry video. For audio, you would have to connect the cd-r output rca jacks to the recorder audio inputs.
Posted on Jan 08, 2013
  • robert frontera Jan 08, 2013
    Thank You Steve for your suggestion. I will try this.
    Bob
  • 1894 Answers
SOURCE: Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
Posted on May 22, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
smarthome2
  • 1114 Answers
SOURCE: My Yamaha receiver model rx-v565 audio is putting
Do not run HDMI to your receiver. Run Digital Coaxial or Optical from cable box to your 565. The problem is on many levels. Hardware, Software, Audio Codecs, etc. your receiver is HDMI version 1.1. The current version is 1.3b. You can thank the recording industry for copyright protection for this issue. To have your receiver updated would be Very expensive and not worth it. If you want a blow by blow explanation of all HDMI's issues, Google HDMI forums or problems, and you can read for hours. Hope this helps.
Posted on Sep 27, 2009
  • 3 Answers
SOURCE: I would like to hook up my components without
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Posted on Oct 18, 2009
mlapres
  • 757 Answers
SOURCE: i just bought a yamaha rx-v365 receiver and hooked
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Posted on Nov 25, 2009
I have yahama audio recver no display and not power on
Check the power supply box/source. Sounds like there's a burnt out component, now by no means am I saying go out and spend 50+ on a power supply. Check the power output and see if you have one with close enough spec, best results use the same spec output
Feb 12, 2015 | Yamaha RX-V571 7.1 Channel Home Theater...
I have a Yamaha RX-V861 that has worked perfectly for years but now I am having an issue. My LG TV makes a popping noise and turns off. It does this 5 or 6 times and then everything works normally. My
If your unit has HDMI Control turn it off on your Yamaha but if it does not have it and your TV does then turn it off on your TV. You can test that theory by unhooking the HDMI cable and using any of the other forms of video output your Yamaha supports, so if you hook it up using component cables or even composite cables we know the problem is coming from the HDMI and the above steps should fix that. Good luck.... http://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=8128
Oct 20, 2014 | Yamaha Rx-v861b - Av Receiver - 7.1...
Picture but no sound when connected to dish network hopper dvr
Lauren Barnett,
How do you have the Hopper hooked up? What TV-to-receiver cable connection are you using? If it's a component cable with three red, white, and yellow prongs at each end, make sure you have it correctly hooked up to the proper ports on the back of both the TV and receiver. You could also try, if you've already verified that, unlpugging the receiver's power cord from its outlet for at least ten seconds and then plugging it back in. I hope this helps!
Mar 06, 2014 | Yamaha RX-V571 Home theater receiver with...
Setting up my rx v2400 to my tv
The setup may depend on your TV and other components and how you plan to use the system. Does your TV have analog or digital audio outputs? The receiver has analog and both types of digital inputs (coaxial and optical).
Use the best cables that you can. You can get all cables at online cable stores for much less than at the electronics big box stores. I'll assume that you already have the speakers connected to the receiver.
Next you can either connect your devices (cable box, blue-ray player) the receiver's inputs. Then connect the receiver's video out to the TV. This is great if you will only listen to the devices with the home theater system. Then you can also connect the TV audio out to the receiver for the OTA TV audio. For this you probably need component video cables and audio cables. These are all cables with RCA plugs.. Then get another audio cable for the analog or digital optical output of your TV. For some TVs the only audio out is the headphone jack. In that case, you also need a 3.5 mm to RCA adapter (the simplest is 3.5 mm M to RCA F/F for connecting to an RCA audio cable). For this method, you won't have to turn off the TV speakers most of the time; the TV won't have any audio.
Alternatively, connect each device audio/video out to the TV's input and then only connect the TV's audio out to the receiver DTV audio IN. Since the receiver doesn't have HDMI, this is the best option if your devices have HDMI out. For this, use the appropriate number of HDMI cables and the analog or digital optical audio cable from the TV to the receiver. Then turn off the TV speakers and enable the external speakers in the TV menu. You can connect to any of the receiver's inputs. If you use the labels, you'll find it easier to turn on the inputs.
If you have any devices with composite video output, use the same basic steps as for the component
The documentation for the RX-V2400 is available at the Yamaha product site: http://usa.yamaha.com/en/products/audio-visual/hifi-components/stereo-receivers/rx-v2400_black__u/?mode=model . You'll need to be a registered Yamaha user (Easy-Pass) to read the manual online.
I hope this helps. Please add a comment with your devices (including the model of the TV) for more specific information.
Feb 19, 2012 | Yamaha RX-V2400 Receiver
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
May 09, 2010 | Yamaha HTR-5840 Receiver
Can you tell me please: where do you insert cables from a cable box to a Yamaha RX-V2500 receiver I appreciate any help you can give. OK. The cables that were attached to my cable box were removed when the...
the coaxial cable from outside is connected to in (box), coaxial cable from out to digital in (RX) digital out to TV... (try scrolling through source to cable/ or component if this is HD) (all other devices can be connect to RX also like dvd using Red Yellow White cable or S-video w/red & white)
Mar 12, 2010 | Yamaha RX-V2500 Receiver
Can I connect component av cables "in" to my Yamaha RX-V365 and connect "out" to my TV and get both audio and video?
Receiver does support 3x component inputs and one component output. Both these can carry only video signal, not audio. So you have to connect audio separately, either stereo via analog 2x RCA connectors and digital SPDIC via optical (2x) or coaxial (1x) cable.
Feb 23, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I just bought a yamaha rx-v365 receiver and hooked to my cable box via a hdmi and optic audio cable. this is working fine but i cant get a dvd player to work via a component and coax audio cable. neither...
Nov 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Digital Audio cutting out
I have the same problem with my RX-V565 receiver. Did you get this fixed?
Albert
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
Yamaha RX-V571 Home theater receiver with 3D-ready HDMI switching Logo
85 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
