Question about Minolta EP4000/5000 CS/PRO Copier
One cassett A4 dose not work in minolta cs pro 3050
  • Minolta Master
  • 1,294 Answers
Pease the error code.
Posted on Jan 29, 2013
  • 126 Answers
SOURCE: Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Posted on Jan 07, 2009
claudiomn
  • 10 Answers
SOURCE: my Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Posted on Jan 17, 2009
Cogz
  • 1326 Answers
SOURCE: code c 0200 minolta cs pro ep 2050
A c0200 deal with the scanner. You may have a blown scanning lamp. Dose the scanner find HP & does the scanning lamp turn "ON" it could also be the Lens HP. Was this code before or after you were there? If it was showing upafter you.. it could be that the Black Box is installed wrong.... Good Luck
Posted on Feb 07, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: i have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Posted on Oct 17, 2009
SOURCE: how to clear M2 on minolta EP 4000/5000 cs/pro copier
how can i clear m3 code on minolta 4000 copier
Posted on Dec 12, 2009
Minolta 4050 giving error code c0160. and noiw not going ahead of welcome screen
The C 0160 code not exist in Minolta EP 3050-5000 series.If the real code is C0610 refer to lens motion failure.Check the mirror reference position sensor and lens reference position sensor.Unplugged and plugged the connectors. 3331bbd5-f151-4464-a6c0-bf018f48f2bd.jpg
Mar 20, 2014 | Minolta EP4000/5000 CS/PRO Copier
I have a Minolta CSPro 3050.. legal paper drawer won't close..and it won't copy
To the rear cover located one hole before waste toner box.Introduction one long screwdriver and push the unlock button.
Jan 18, 2013 | Konica Minolta Copier Toner EP6001 CS Pro...
Reset Minolta cs pro 3050 to Factory
Co920 - 1st cassette problem
Co910 - 2nd cassette problem
Co900 - 3rd cassette
Co950 - 4th cassette
Open and close the front after copier is ON,if the message is apper enter in the service mode,or pull out the cassette failure and work.
Service mode enter:press STOP - 0 - STOP - 1
Check the actuators in the cassette,feed rollers and the sensors.
Jan 08, 2013 | Minolta EP4000/5000 CS/PRO Copier
Error code C0320 for cs pro 3050
Please deescribe your roblem/reset the malfuntiion code open and close the front door or turn OFF the power witch and tray again to turn .
Aug 13, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta cs Pro- Works but print black copy?
Please clean the mirror unit,the trasfer and separator coronas,and perform F5 AIDC control.
May 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
Both paper cartridges malfunctioning of minolta 4000 (i dont know the solution)
Do you see a small wrench in the bottom left corner of the displa pannel? If so press the wrench and the display will change then open and close the front door and try to open the paper trays. If it dose not work you may have more then a basic problem. Good Luck
Mar 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Code c 0200 minolta cs pro ep 2050
Feb 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
I thinking of buying one of these machines
The Minolta EP-5000 is a analog copier. That means that it can not be connected to a computer to print to, it is just a 50 a minute copier.. It is to old to be connected, it came out around 1996 or so..... It is naot a bad copier, it is one of there old work horse... It is a up-dated version of the EP-3050 & 4050.
Dec 04, 2008 | Minolta EP4000/5000 CS/PRO Copier
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
