I have a copier, printer, fax, scanner Toshiba e-Studio 3511 that shows error code CE50. Anyone can tell me what that means?
That is a auto toner sensor error code. Your machine most likely needs to be cleaned. That machine model will only cause you problems if all of the machine modifications are not done. You will need to take the left side cover off and completely clean inside the machine. Well worth the money to get a technician out to fix. Your machine will need to be re-calibrated.
Posted on Jan 21, 2009
Getting error sc 479627 toshiba e studio 3511
479627 is your meter not the error code.
3511 and 4511 color machines will be obsolete at the end of this month. Advise you call your local Toshiba dealer and talk to them about a trade in upgrade.
Jan 13, 2013 | Toshiba E-Studio 3511 Color Copier
MY TOSHIBA E STUDIO 451c HAS AN ERROR F100 CODE. WHAT DOES IT MEAN?
That code error meaning that you have a problem with HHD
1st you reboot your machine with push 0+8 than 690 start 2 set(interrupt).
If it don't wok you mast replace your HHD with a new one from Toshiba.
Aug 11, 2012 | Toshiba E-Studio 3511 Color Copier
How to reset error code c21 in the Toshiba e studio 166?
how can to reset error code c21 my toshiba e-studio 166 printer
Feb 28, 2011 | Toshiba e-STUDIO166 Printer
Can you please giv a soluton for this issue: error code CE 40 toshiba e studio 3520
CE40: Image quality control test pattern abnormality: The test pattern
is not formed normally. If you switch off at the right hand side of the machine, wait
10 secs then back on again, It should clear. I think it is caused by condensation.
It can also be transfer belt failure, or paper rubbing against the transfer belt. It could be
because the Developer Unit failed to Pass the Close Looping Check by the machine
every time it boots.... check for fault from 08-824 if the value of any color is " 1 "
means abnormal occur.... check for foreign matters on the dev tank...the
simplest way is clean all 3 tanks...then reset it back to "0" then do a 05-200 and
05-396-4-Fax-1624-Set
95% solved the case
Jan 15, 2011 | Toshiba E-Studio 3511 Color Copier
Toshiba 3511/4511 suddenly stopped faxing
Try use the monitor button for faxing, check whether there is tone or not.
Jul 08, 2010 | Toshiba E-Studio 3511 Color Copier
F 105
How do u get in service mode on a toshiba 3511
Nov 06, 2009 | Toshiba E-Studio 3511 Color Copier
Cant recieve fax on Toshiba estudio 3511
Hello sir; For the fax line only have two single lines working in the cable one is in-coming ,another one is out-going, therefore if you can send fax and can not receive, that's means your phone cable or phone jack on the wall have problem, my sugestion, replace phone cable first, if still have problem check the phone jack on the wall.
Jan 23, 2009 | Toshiba E-Studio 3511 Color Copier
I have a Toshiba E-studio 650 with a C46 error code.
Hello sir; The error code you post out it's means "fuser pressure roller thermistor bad let's try to reset if don't work have to replace it;
Turn power off , press and hold down 0 and 8 while turn on the power, enter 400, press start,enter 3 ,press start, enter 0 press set or interupty. turn power off and back on again.
Jan 10, 2009 | Toshiba E-STUDIO 650 Copier
174 people viewed this question
k24674
jasbo
jasbo
