Question about Intuit Quicken 2008 Home & Business Full Version for PC (403616)
No sound on quicken - Intuit Quicken 2008 Home & Business Full Version for PC (403616)
Is quicken 99 compatible with windows 8?
If you have some technical knowledge then follow you can Upgarding your Quicken by http://quicken.intuit.com/compare-quicken-personal-finance-software-products.jsp.
When you install and start the latest version of Quicken for Windows, it automatically looks for the last Quicken data file you
used, and walks you through the simple steps to converting it.
If need any help and guidance follow Intuit Support Number
Jul 04, 2014 | Intuit Quicken Deluxe 99 for Windows...
I installed quicken 2011, but am unable to turn the quicken sound on, Iused quicken help, which told me to go to file menue>preference, I did that but when I opened file i did not have the...
You can follow the following steps to have the sound enabled in Quicken 2011.
  1. Ensure your Quicken program has been updated to the latest release.
  2. From the Quicken Edit menu, choose Preferences, and then choose Quicken Program.
  3. Select Setup, and then select the Turn on Quicken sounds checkbox, and then click OK.
  4. If the issue persists, make sure that your speakers have not been muted and that the sound volume is correct (refer to your operating system's Help for instructions).
    Note:
    Quicken sounds will only be available if logged in using the same user profile that was used to install Quicken.
  5. If Quicken is unable to produce sounds despite following the above instructions, Reinstall quicken in selective startup.
Note: This process requires you to restart your computer.
Restart your computer in Selective Startup Mode, and then install Quicken.
To restart the computer in Selective Startup mode:
  1. Click the Microsoft Windows Start button and select Run.
  2. In the Open field, enter MSCONFIG, and then click OK.
  3. On the General tab, select Selective Startup, and then select Load System Services (ensuring all others are unchecked).
  4. On the Services tab, in the area below the scrolling list, be sure that Hide all Microsoft Services is not selected.
  5. Click Disable all to clear all selected services.
  6. Select Windows installer, and then click OK.
  7. When prompted, click Restart.
  8. When your computer restarts, run the Quicken installation from the CD-ROM.
    When you place the Quicken installation CD-ROM in your CD-ROM drive, the Quicken installation should start automatically. If it does not, you can start it manually:
    1. Close all open applications.
    2. Click the Microsoft Windows Start button and select Run.
    3. In the Open field, enter D:\INSTALL.EXE, where D is the name of your CD-ROM drive.
    4. Click OK, and then follow the on-screen instructions.
After the installation process completes, return your system to its previous configuration:
  3. On the General tab, select Normal Startup.
  4. Click OK, and then click Restart.
the installation is not successful, try installing from your hard disk. For instructions see below.
Copying Quicken to your hard drive and installing it from there resolves many of the issues that can occur during installation.
  1. Right-click on your desktop and select New > Folder. This creates a folder named New Folder on the desktop.
  2. Place the Quicken CD-ROM in your computer's CD-ROM drive. If you are prompted to install Quicken, click No or Cancel.
  3. Click the Microsoft® Windows® Start button and select My Computer.
  4. Right click the CD-ROM drive with the Quicken CD and select Copy.
  5. Open the New Folder created in step 1.
  6. Select the Edit menu and select Paste. This copies the contents of the Quicken program from the CD-ROM to the hard disk. When the copy is complete, the DISK1 and Custom folders appear in the New Folder window.
  7. Double-click the DISK1 folder to display the contents, and then double-click Setup.exe.
  8. Follow the on-screen instructions.
Jan 17, 2011 | Intuit Quicken Deluxe 2011
Quicken Launcher won't work
Usually RegKey of previous version isn't removed.
Mar 20, 2010 | Intuit Quicken Deluxe 2009 Full Version...
I just installed Quicken Starter 2009 for my wife's accounts. In the process I lost my own Quicken 2008 on the computer. I want both of them. What can i do to show both icons
Quicken Starter can coexist with QuickBooks, but not other versions of Quicken. Quicken Starter is intended for customers who do not have any version of Quicken already installed.
Apr 09, 2009 | Computers & Internet
Backing up a Quicken file
This is probably due to an update. Quicken and quickbooks perform updates in the back ground on a frequent basis. The easiest way to take care of this problem would be to create a directory called backup on the flash drive and instruct quicken to backup to it.
Provided you're using windows XP, click on My Computer, select the icon for your flash drive, F: Right click and create a new folder and name it backup. In quicken when you go to backup, just change where it says F:\ to F:\backup
this should fix your problem. Please email back if you have any problems getting it to work.
Dave
Feb 28, 2008 | Computers & Internet
Tool Bar missing at start up
Edit > Preferences > Quicken Program > Register
Uncheck "Maximize my register view".
Feb 26, 2008 | Intuit Quicken 2008 Deluxe Full Version...
Intuit Quicken 2008 Home & Business Full Version for PC (403616) Logo
Top Intuit Computers & Internet Experts
Scott Fair
Scott Fair
Dan Shibata
Dan Shibata
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
