Fujitsu laptop i can't open it
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Jan 08, 2013
The heating is not working at all on my fujitsu air conditioner
Should have an heating element inside...that one I think is broken or can be also the thermostat..
Jul 12, 2013 | Dishwashers
Can't access bios; win vista won't load.
To get to the Bios you need to press the F2 button during the Fujitsu Splash screen.
If all you get is beeping, then it sounds like a bad keyboard on your laptop (could be a stuck key). If an external keyboard does the same thing. I would reset the cmos (unfortunately the laptops have their cmos sodered on, theres youtube videos on how to do it for laptops)
Oct 26, 2012 | Fujitsu AMILO Computers & Internet
Wifi & Bluetooth does'nt work anymore
Hi ,
it sounds like you need to reinstall the drivers , what operating system do you have ,,,,,,,,let me know Roy
Feb 18, 2012 | Fujitsu Siemens Fujitsu LifeBook E8420...
I can't find the driver for my build-in webcam on my Lifebook P8010. Please help.
Since I don't know which operating system you have, I've included links for the 3 most common Windows versions. You cannot click on the download button until you put a check in the box stating you agree to the terms of service.
Windows XP: http://support.ts.fujitsu.com/Download/ShowDescription.asp?SoftwareGUID=3616BFC3-7DF9-43D1-B553-0207B97179E6&OSID=665F4A20-6E31-43C3-82C2-D98CE773007C&Status=False&Component=WebCam
Windows Vista: http://support.ts.fujitsu.com/Download/ShowDescription.asp?SoftwareGUID=2EFB68E4-F50B-4893-8D51-79B9528915C4&OSID=DD13C337-8EFF-4CFB-A589-72971D7BCBCE&Status=False&Component=WebCam
Windows 7: According to the manufacturer, the driver is included in the operating system.
I hope this helps and thanks for using Fixya!
** If you found this helpful, please leave a great rating so others may benefit from this answer! **
Sep 23, 2011 | Fujitsu Lifebook P8010 Notebook
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
Hi,I Have Bought a Esprimo V6545 Last year.Unfortunately following a Fall Accident,My Laptop didn't work because of a bad sector in Hard.so when i replace that segment i have missed Bluetooth &...
maybe as a result of missing drivers try to download and install bios chipset bluetooth in that order from
http://ts.fujitsu.com/support/downloads.html
yu may have to select your model laptoop from a list
its as you stated Esprimo V6545
Jun 01, 2011 | Fujitsu Computers & Internet
Fujitsu siemens d 7820 i miss graphic after to instol new xp
If it is the graphic's driver that is missing, you can go to the Fujitsu Support > Downloads page to obtain the latest drivers for Windows XP.
  1. Go to http://ts.fujitsu.com/support/downloads.html
  2. In the 'Product Search by Serial-/Identnumber' searc box, type AMILO D7820.
  3. Once the page opens, verify that 'Windows XP' appears under 'Selected Operating System'.
  4. In the list which appears, click on the '+' near graphics.
  5. Select the version of the driver you want and click on the download link.
Really hope this helps you.
May 16, 2011 | Fujitsu AMILO D-7820 Notebook
How to get round bios password on fujitus amilo
To reset the BIOS password read the information from this link.
In case of your Fujitsu laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
May 02, 2011 | Fujitsu Siemens Amilo Li1818 Laptop...
Hi, i need to get access to my ethernet connector to replace it. i've broken it. it's on a fujitsu siemens L6820. thanks!
More easy is to buy one of these USB to Ethernet adapters & plug the network cable into them:
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=589&name=10-100%20Ethernet%20USB
These are cheap & you don't have to disassemble your notebook & re-solder a new Ethernet connector, let alone finding the correct one.
Apr 18, 2011 | Fujitsu Siemens Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
