Question about Traxxas Rc Revo Nitro Monster Truck
My glow plug isnt getting hot
I have changed the glow plug twice it is not geeting hot
Please check your battery and also check your glow plug wire it may be damaged .
Posted on Jan 26, 2013
1996 Nissan Safari SWB 4.2 turbo auto new glow plugs but will not fire unless you glow it at least twice any ideas
timer for glow plugs not giving enough time ?? it should change times with the temperature ,but 96 ? maybe not may need a head overhaul with the valves ground in or new piston rings or both ,does it have starship mileage on it ?
Nov 10, 2016 | Nissan Cars & Trucks
Tip
Checking glow plugs for Ford and Chevy diesel engines
If you need to check glow plugs on a Ford or Chevy Diesel engine, run a hot wire from your battery. un plug the glow plug wire and strike the hot wire to the end of the glow plug. If you get a spark the glow plug is good. you should do this to each one, but one at a time then replace the glow plug wire as you go.
on Mar 03, 2009 | 2001 Ford Explorer Sport
Wiring diagram for glow plugs
The glow plugs are programmed by the ecu, you will have to take it to a dealer who has the ability to change it if possible, the best thing you could do is turn the ignition on and off a couple of times before you start the engine, that should get the glow plugs hot enough to start.
May 11, 2014 | 2006 Mitsubishi Colt 2800
I bought a van 2003 Mercedes mb140 diesel. Is always gone and Also the mechanic gave me the ok. Then i wanted to sue but the light for the engineering start didn't turn on anymore so the engine didn't...
check the glow plug relay / and fuse. if thats ok then you will need a meter on the glow plug wire to see if there is any resistance on the glow plug its self. if the relay is at fault just change it. glow plug has no resistance then it needs changing. if the fuse has blown check the wire loom for the glow plug wires as they can get hot and earth to the engine.
Feb 22, 2014 | Cars & Trucks
Tdiclub.com
THE SMOKE YOU HAD IS BECAUSE MANY TRIES TO START COLLECTED FUEL IN THE COMBUSTION CHAMBERS AND SUDDENLY BURNT ON START. ANY WAY THE HESITATION OF CRANK START FOR LONG TIME CHECK WHETHER YOU DO NOT HAVE A PROBLEM WITH THE FUEL PUMP,FUEL FILTER OR COLD START SENSOR. CHECK YOUR SPARK PLUGS CLEAN THE THROTTLE BODY AND DO WITH SCANNER THE ADAPTATION.S
Aug 29, 2012 | 2001 Volkswagen Jetta TDI
2000 peugeot 306 1.9 diesel smokey on startup and misfiring when cold but is ok after heating up no wAater loss any ideas
change the glow plugs i used to have a 306 and a huge cloud of white smoke come out of the exhaust on start up lol, changed the glow plugs and was clear as a whistle, its because the glow plugs dont get as hot as the others and fires up on the hottest cylinders so if you have two glow plugs out the other two are being forced to turn over hope this helps you ;)
Nov 15, 2009 | 2005 Peugeot 405
I have a 1994 2.8ltr Diesel (4M40 Mtr), Delica, that conks out
try changing all the heater plugs there are warn out by now,,if it realy dont like starting up on cold days do what i do,,, give it twice the heat up time,,,,,
turn on the kye wate till the heater light go's out then quikly switch it off and turn it back on for a re-heat before trying to start it up,,,also try changing the glow plug heater relay,, it should hold the glow plug heaters on for about 30 seconds after the light has gone off even if the engen has started and is running
but i bet its not doing this? giving twice the heat takes less out the battery than cranking it over and your not wearing out the starter as well?
doing this to my old girl gets her going every time!!!!!
Oct 26, 2009 | Mitsubishi Passenger Cars & Trucks
The dryer gets hot then gets cold. changed the glow plug but problem still exists
check the thermolstat isnt covered in **** and over heating
Jul 25, 2009 | Dryers
Traxxas Rc Revo Nitro Monster Truck Logo
48 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
