Question about Price Pfister Plumbing
Cagney F-529-7CG WKP-40
I just installed this faucet. Turned the water on at the valves, checked for leaks, looked great. When I stood up, and turned the faucet on, I got nothing. I heard the water getting to the faucet, beu I can't get it to come out. Did I forget to remove something, It is brand new, looks great, but the wife aint going to like this...Know what I mean.???
  • 68 Answers
SOURCE: Faucet leak from the connection with spout.
Return the new faucet for another one. The o-rings in the base of the spout are leaking. Either installed wrong at the factory or defective rings.
Don't fight with it, trade for a different one.
Please rate this answer and Good Luck, Phil
Posted on Dec 29, 2008
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
  • 10865 Answers
SOURCE: Greetings! My Kohler kitchen faucet
Begin by shutting off the water to the faucet. Then, on the back of the handle you will find a small button. remove it with a small knife blade and underneath you will see a 1/8" set screw. Use a 1/8" inch allen wrench to remove the set screw. You can then unscrew the bonnet and remove the diverter. Take the diverter to a hardware store or plumbing supply to purchase the appropriate repair kit. goodluck.
Posted on Jan 21, 2009
broii4x4
  • 13 Answers
SOURCE: Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Posted on Mar 24, 2009
  • 4 Answers
SOURCE: Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Posted on Jun 13, 2009
I recently installed a Pfister Cagney Single control kitchen faucet with side spray. The spray has no pressure. The water from the faucet is great. What could be the problem?
Could be trash got into hose( i.e., teflon tape, brass shavings, etc.). I suggest that you turn off water, disconnect the hose and try flushing water through the hose with no sprayer attached. If water goes through, then you have a stoppage in the sprayer. The face of the sprayer usually unscrews allowing you to check if there is trash in it.
Apr 09, 2015 | Plumbing
Hot water doesn't work
Does any water come out of the faucet when turned to hot? If not, you may have disconnected the fautet line from the valve and attached the dishwasher line. You can check this by looking under the sink and making sure all lines are connected to valves.
If everything is connected, you may have dislodged some mineral buildup and it is blocking your hot water line to the faucet. You'll have to remove the line and clean it out.
Mar 02, 2014 | Home
Installed a tankless gas hot water heater a few months ago, and ever since then when ever I turn on the hotwater, I get pockets of air coming out of the faucet. There are no leaks in the water lines, but...
1) Never, ever install tankless water heater, unless your wallet is 2" thick and you enjoy nuisance problems and recommended continual maintenance.
2) Add in-line air vent.
http://waterheatertimer.org/images/Air-vent-added-to-return-22.jpg
3) Look for check valve along the line. Look for mixing valve, pressure regulating valve, etc.
4) If you have recirculation system, remove cross-over check valve and see if problem is located there.
5) Contact Rheem. 800-432-8373 They will want model number, serial number, and name of installer. And might recommend contacting installer or plumber.
6) Increase water flow. Check water flow requirement of tankless (.5 gallons per minute activation) with actual flow at faucet.
7) Clean water filter at tankless unit.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
8) Crossover at single-handled faucet.
http://waterheatertimer.org/Crossover.html
9) Fix all leaking faucets indoor and outdoor so no air is being sucked in.
10) Bad TP valve on water heater sucking in air each time water pressure pulls on the valve?
Additional resources: No information about air-in-line
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Sep 20, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
I just had a new price pjister series 40 (Ashfield collection) single control lavatory faucet installed. Our contractor installed it yesterday and he is now out of town for a week. Since the sink and...
You have already checked the two obvious things now make sure the two supply lines from the shut off valves are not kinked or turned it such away as to close off the water flow. If that is ok then there may be some debris in the internal filter screens.
Keep in mind that this faucet design will not put water out at a high pressure if it did it would splash all over the place.
Mar 08, 2011 | Price Pfister 042-YP0E Ashfield Single...
No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
Apr 01, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
We recently installed a new bathroom faucet and it
check the strainer where the water comes out of your faucet it may be clogged or if the faucet has a cartridge in it it may be clogged and you will have to dis assemble the faucet to clean it usually the strainer is the problem and it should unscrew by hand
Mar 11, 2010 | Plumbing
I just installed a new cartridge in a moen single handle bathroom faucet. Works great except no hot water. The hot water valve is turned all the way on.
try and pull the cartridge out and look in there with a flash light and make sure there isn't any think lodged in the hot water side of the faucet, you might even want to leave the cartridge out and turn the water back on to try and flush it out. alot of times rubber from the old cartridge gets stuck in there as you are pulling the old one out especially if it's stuck in there good
Jul 29, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Removing anoide.
You will need to turn off water,electric.Release psi.and look at the middle of water heater and you will see a big bolt like thing.You will need a big wrench or socket to remove it.
Mar 15, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Replaced moen 2225 cartridge leaks when valve is turned on
is this the single handle model? if so simply remove handle, plate, then pull the clip out with a pair of needle nose (after turning main water off).
the valve assembly will pull staright out with moderate force. sounds like one of the small o rings got pinched so it may take a good pull.
make sure to look inside valve housing for foriegn debre. clean it out good. i like to turn the water on for a few seconds before i put the new valve in to blow out any stuff that might cause problems.
Mar 07, 2009 | Plumbing
Plumbing Logo
213 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
