Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
When we flush machine runs and waste goes properly but waterlevel goes high . during flush time the toiletbowl filled with water
  • 41 Answers
Sounds like your external pipe may have a blockage tap the pipe to see if your hear a thud if it sounds clear check the toilet outflow pipe the same.. You may need to have your external pipes rodded.
Posted on Feb 07, 2013
3 Suggested Answers
  • 17 Answers
SOURCE: This was just installed. When it is flushed the
If there is a air emiten valve on vent ? Remove it than try to see if it works properly. If this works you will need pipe vent outside
Posted on Dec 22, 2009
Testimonial: "Thanks! You fixed it! Not enough suction to open the rubber valve in the vent pipe. I took the rubber valve out, now works great!"
  • 115 Answers
SOURCE: Sanipro continuously runs,however, not pumping
There can be a blockage somewhere in the discharge pipe, the blade or impeller. Also the short discharge pipe or long elbow inside the pump casing may be split open or not attached properly and waste water is just cycling inside the pump casing. Worst case scenario could be a bad capacitor, the capacitor spins the blade and impeller, it that goes bad the unit will just hum and not pump any waste out until is replaced. You can also order parts through Saniflo if needed.
Posted on Jan 11, 2011
Why doesnt town water cut off and just keep filling the tanks till they overflow we have tryed everything
Troubleshoot Your Toilet Without a Plumber
www.popularmechanics.com/home/how-to/a4117/4303948/
Overflowing, constantly running and sweating toilets can test a home owner's sanity. ... take for granted--until we can't take a shower or make the toilet flush properly. ... If none of the above does the trick, you may have a misadjusted or faulty fill ... the waterlevel a half inch below the top of the overflow tube inside the tank." ...
Emergencies - Overflowing toilets - Toiletology 101
www.toiletology.com/emergenc.shtml
You can't just lower the water level in the tank; you need to displace some of ... and the ballcock and flapper are working properly and shut off when the tank is full. ... The bowl is filled with the water that goes into the overflow pipe. ... Unfortunately, when a toilet bowl is clogged and the water level rises and doesn't flush the ...
Nov 19, 2015 | Town Home
How do I get the water to stop filling the tank on my toto ST794S toilet?
there should be a screw adjustment on the ballcock or fill assembly...screw that down some to adjust...that regulates your tank water level....that screw goes in or out to adjust...one or other should do the trick...may have to do this a few times to get proper adjustment...good luck..
Jul 07, 2014 | Toto St794s-12 Nexus Tank With G-max...
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
Can't get enough water in toilet bowl to flush the waste
Adjust your tower to let the bowl fill up more.....google your problem if you dont understand...depends on what kind of tower you have....should have teeth on the tower itself to make it fill more...try pulling up on the float...
Mar 15, 2012 | Jacuzzi Bath Perfecta EZ33 959 White round...
Water keeps running after it fills up, won't shut off
On the outside of washing machine tubs there is a rubber hose that goes from the tub to the level sensing unit in the control hood. I have seen these fall off. If it hasnt make sure that it is clear of debris and water. If all is ok here is a link that tells you how to check your level switch, http://www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
Good Luck
Sep 26, 2011 | Kenmore Washing Machines
When we run the humidifier the waterlevel does not change.
The humidifier and it's tubing may be clogged with calcium deposits and scale. Especially so, if you're using well water or your city's water has high calcium deposits.
Empty whatever water is in the unit and refill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Allow it to sit for 30 minutes and then turn the unit ON. Once you feel moisture coming out, allow it to run anoter 10 minutes or so. Then turn the unit OFF and empty the remaining solution (if any is left). Now, flush the system by filling it with Bottled Distilled Water and running it.
For future use, I'd recommend that you use nothing but, Bottled Distilled Water.
Apr 07, 2011 | Vicks V3100 1.2 Gallon Humidifier
How to fix fill water shooting up and over when flushing?
I don't exactly know what you mean so i will cover all the basics. The fill valve sends fills water in 2 locations. 1) the fill valve fills at the low end (from the bottom to the top) of the tank. This is the flush water level. It needs to be stopped by a float switch before the water overflows into the over flow tube.
2) the fill valve fills water via a small tube at the top of it which this tube NEEDS to be pointed into the overflow tube with a high arch. THIS water is filling your toilet bowl section to proper flushing height. If your water in your bowl does not reach proper height and someone removes this tube to aim it into the tank where the other water is stored, THEN you may have the problems you described and you will need to do several flushes to remove waste.
SO to reiterate 1) make sure your float cuts off and stops the filling cycle before the water flows into the over flow tube. This is done from 1 or 2 adjustment screws. and 2) make sure the small black tube is aimed down into the over flow tube with a good arch. The arch prevents back siphon.
Mar 19, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Washing machine wont fill with water when switched on
Fillingwith water:
The waterfill valve - The water fill valve is a mechanical and electrical part,the coils on the valve need electricity to mechanically open the valve to allowthe water to flow into the washer....myth....the washer pumps water into itself...no, itdoes not. The fill valve opens and the house water pressure pushes the waterinto the washing machine.
No cold wateror no hot water - The fill valve has two coils, one for the hot water and onefor the cold water. It is possible that one of the coils can fail and you loosethat filling ability. If the cold water coil quits, the hot will still work andduring warm fill you will get hot water only and during a cold fill you willget no water at all. If the hot coils quits, you will still have cold waterfill, cold water only on a warm setting and no water on a hot fill setting. Youcan No cold water or no hot water- The fill valve has two coils, one for the hot water and one for the coldwater. It is possible that one of the coils can fail and you loose that fillingability. If the cold water coil quits, the hot will still work and during warmfill you will get hot water only and during a cold fill you will get no waterat all. If the hot coils quits, you will still have cold water fill, cold wateronly on a warm setting and no water on a hot fill setting. You can testa fill valve live for 120volts, power to a fill valve coil and no fill = a bad fill valve. You can also testthe coils for continuity, nocontinuity = a bad fill valve. Some Maytag washers have a fuse in the fillvalve circuit, if this fuse let go the washer will not fill. Fill valves canalso from time to time stick open and not stop filling. If you have to shut offthe fill valves to stop the water fromfilling in the washer, you have a bad fill valve and you will have to replaceit.
Water level controls - The water levelcontrol is also know as apressure switch, this is where you set the water level ( small - medium - large). The water level control is responsible to shut off the power to the fillvalve and direct that power to the timer so the washing machine can start up.The WLC has electrical contacts in it that sends power to the fill valve and whenthe WLC is satisfied the water level is correct the electrical contacts openpower to the fill valve and send the power to the timer and the washer starts.Picture of this here. How the water level control knows when it istime to shut the water off is, a air tight hose runs from the outer washer tank to the waterlevel control. As the water fills the outer tank air is pushed up the hose,depending on which setting you have made ( small- medium - large ) is takes acertain amount of this pressure to make the WLC cycle over and shut off the waterand send this power to the timer. If this hose develops a leak or a pin holethe washer can over fill as the WLC may not be able to shut the water off. Thewater level control can also break down and allow the washer to over fill aswell.
Testinga water level control or a fill valve can be done by using a Testing a water level control ora fill valve can be done by using a ohmmeter or a voltmeter. Testing a waterlevel control or a fill valve can be done by using a ohmmeter or a voltmeter. Testing a waterlevel control or a fill valve can be done by using a ohmmeter or a voltmeter.
You can get required parts from www.repairclinic.com
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Jan 16, 2010 | Zanussi FJS1225W Front Load Washer
Waterintake stops after approx. 35 sec.waterlevel is to low,detergent compartement will not open because of low waterlevel and also water will not heat, because heating element is not covered with water....
The machine fills by time only as you have already determined. The intake screen on the water valve is probably plugged up and cleaning it should solve your problem. You will have to turn off the supply to the dishwasher and disconnect the water feed line. Eric
Sep 15, 2009 | Dishwashers
Water overflowing - GE wvsr1060a1ww top loading washer
since the water stops running in and goes to the agitation mode when you blow on the tube, it is more than likely the pressure switch - one thing to check though, put it in the fill cycle [with water running in] and unplug the power cord. the water should stop running in. if it doesn't, the fill valve is sticking open and should be replaced
Aug 16, 2009 | GE Washing Machines
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
167 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
