What's the Best Converter Box for My Old Panasonic CT-1110 D TV?
My TV is an older model Panasonic TV, Model # CT-1110 D, Made in 1984. Has 1 VHF (Coaxial Outlet Jack) and 2 UHF Knobs. Has no antennae, don't think I'll need it, as I won't need it for cable. My main goal is to watch old VHS tapes on it. I'll be using a GE VG4025 Video Tape Player. Thanks for any information and encouragement.
SOURCE: Does a CT-27614A need a digital converter for antenna?
Yes.
Posted on Mar 03, 2008
  • 520 Answers
SOURCE: New TV Converter Boxes
If your talking about a digital converter box, it goes between the antenna and the tv.
Posted on May 13, 2008
  • 520 Answers
SOURCE: Digitial TV Converter
The antenna connects to the ant jack on the digital converter box. The cable you are describing goes from the tv jack on the box to the ant jack on the tv. If this does not work we will need more info. Hope this helps.
  • 21 Answers
SOURCE: Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Posted on Jan 27, 2009
  • 57 Answers
According to http://www.dtv.gov/consumercorner.html#faq9
I hope this soultion is helpful.
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Posted on Feb 12, 2009
I have an old model Panasonic tv. model PV-C2021. What is the best Converter Box and Indoor Antenna to use?
any box will do. but indoor antennas that is different. what area do you live. depends on what type of arial you need.
Sep 24, 2013 | Televison & Video
How do I get my Panasonic CT-26WX15N to accept digital signals?
If you are using an older tv then yes you need a digital converter box to convert digital to an analog signal the TV can understand.
Oct 06, 2012 | Televison & Video
Cannot find channel 3 or 4 on old Panasonic TV CT 20S2S
Channel 3 or 4 is what you select on your actual television. using the TV remote press 03 or 04 ( whatever the converter box output is switched to on the back.
if you cannot get the tv to select 3 or 4 ( not programmed try searching for channels on the convertor box and after it finishes auto program the TV set.
For a more detailed specific answer please list the make and model of both the TV and the digital converter box
Mar 13, 2009 | Televison & Video
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Analog or Digital?
This TV is analog and will need a converter box when Analog TV is turned off in 2009.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 10, 2008 | Panasonic CT-20D11 20" TV
Can't tell if we need converter box for a Panasonic TV CT 27SC14J
this tv does not have a digital tuner. so, if you used an antenna to get off air channels, you would need a converter box. however, if you have cable or a satellite dish you will not need anything.
Oct 15, 2008 | Panasonic CT-27SC14 27" TV
Panasonic ct 32sl14 flat screen tv
Sorry no, it does not have the correct tuner, however you do not need a converter box if you are connected to cable or satellite
Jul 17, 2008 | Panasonic CT-32SL14 32" TV
May 09, 2008 | Televison & Video
Panasonic Television
The CT-32G19 is a standard TV you will need a converter
Mar 19, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
