Question about Compaq Armada M700 Notebook
WINDOWS IS FAILING TO BOOT - Compaq Armada M700 Notebook
  • Compaq Master
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Jan 08, 2013
1720 smart hard drive detects imminent failure failing attr 05
go to hp website and download the latest firmware for your notebook
Nov 23, 2013 | HP 530 Notebook
Dell p15s
Is it failing to show anything on the screen? Failing to boot?
Some basic troubleshooting steps:
1. If nothing comes up on the screen, first try removing your battery for a few minutes without the charger plugged in. Attempt to turn it on (it won't, but it'll discharge the capacitors). Then replace the battery and charger and try to boot.
2. Use the windows install disc to repair the operating system, simply insert it, boot from it (use F8 to select it if you need to) and hit repair when the window comes up.
3. Also, sometimes connecting to an external display (use the VGA port) can help troubleshoot whether it is a display, or a boot issue.
Jun 14, 2013 | Computers & Internet
File: \Boot\BCD Satus: 0xc0000098 Info: The windows Boot configuration data file does not contain a vaild OS entry. I have a windows installation disc
boot to the Windows DVD, select the option to REPAIR, If this is only a software issue, that should resolve.
If it doesn't then run diags on the HDD is it may be failing
Jan 15, 2011 | Computers & Internet
My computer wont boot windows but say's: windows could not start because the following file is missing or corrupt ;windowssystem32configsystem. What can I do?
Boot to you XP CD< press R for recovery console, run CHKDSK /R see if that resolves.
If not, hold Fn While powering on the system and run diagnostics the Hard Drive might be failing
Jul 27, 2010 | Dell Inspiron 1501 Notebook
Will not boot
If you dont have the option to run:
"Windows XP Recovery Console"
You probably have to install windows on a second PHYSICAL drive, Disconnect the failing one first!
Reconnect the failing drive in slave mode.
1. Start/Run "cmd.exe"
2. execute "chkdsk /F /R /X D:"
3. Shutdown
4. Swap drives.
5. Start system (while praying :) )
Jul 18, 2010 | Microsoft Windows XP Home Edition
My problem is my mainboard being a m2n mx se plus [replacement board] is only a two days old.When I ripped a cd to my 2nd harddrive it came up with following Delayed Write Failure and then later on this...
Check your second harddrive. First check its connection try to reseat it. Secondly, maybe its failing and somehow messing your CPU to boot up. You could try to disconnect your second harddrive for the meantime its power connector and interface cable. Then boot up with only your 1st drive where your OS is installed I suppossed.
Boot up, if this boot with no problem, 2nd harddrive is failing.
Apr 04, 2009 | ASUS P4V8X-X Motherboard
Failing to boot
can you press f8 at atrtup and get into safe mode
Jan 16, 2009 | HP Compaq nc6120 Notebook
Windows xp keeps failing
check the bios and see what the boot order is for the boot devices. Hard disk 0 should be listed after the cdrom drive. this problem you are having might occur if the hard drive is down the list in the boot order, and not checked as being a valid boot device.
Sep 26, 2008 | HP Pavilion dv6000z Notebook
No screen after Boot
Try booting to the safe mode (f8) and see if there is any difference. If there is no difference, the video adapter is most likely failing.
If you can boot into the safe mode, then reboot and try the vga mode on the same menu, if you can boot to the desktop, then try to increase the resolution. if it fails, try a new video driver.
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
Failing to log on Asus Laptop L7200 with windows xp professional
can you explain if its the initial logon to enter the bios and set up; or the windows log on to boot into your desktop
Jul 03, 2007 | ASUS COMPUTER (S6FM-1P028C) 11.1INCH 1366...
Compaq Armada M700 Notebook Logo
15 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
