Question about PIAA 2002 Chevy S10 Pickup - All S10 Pickup models - Xtreme White Bulbs
WHEN i WENT TO START MY S10 PICKUP THIS MORNING IT WOULD NOT START. IT DOES NOT TURN OVER EITHER. ALL THE LIGHTS WORK . ANY IDEAS?
    Sergeant:
  • 248 Answers
BH is right on there, dirty battery connections is most likely and also mean your alternator cannot charge properly. If it turns out the battery and alternator are ok it is probably your starter motor.
Posted on Jan 08, 2013
    Sergeant:
  • 291 Answers
Step one is to clean your battery cable connections. Remove the negative cable first (this is important.) When reconnecting neg cable goes on last. Clean the battery posts with wire brush and scrape the inside of the conector with pocket knife or similar tool. If you have a battery charger, charge the battery. If after reconnecting still not enough juice, take the battery to wal mart or autozone etc to be tested. They should do it at no charge. If the battery tests good then you are probably looking at an alternator problem. Beware though I've seen same symptoms from a loose ground wire. Autozone will check alternators and many other parts for free. So does Oreilly's.
1998 chevy S10 4x4 passenger rear turn signal and break light not working
I would try measuring for 12 volts at the socket while the turn signal is on.
May 11, 2017 | 1998 Chevrolet S-10 Pickup
My 1999 Chevy S10 4.3L won't start in the cold with a brand new battery and alternator. This only happens in 10 degrees(F) or below. What could be the issue?
I forgot this one: check the contacts of all power cables. Cab;es in the start circuit. Eventually, by hand. When you can wiggle them around there will be a too high resistance on that connection.
Feb 23, 2015 | 1999 Chevrolet S-10 Pickup
When driving my Why would my s10 just quit
sounds like a loose power connection or bad wiring in the engine compartment. Check battery cables and ground connections at both ends of wires and cables first. If the problem remains, test equipment and a wiring diagram would come in handy.
Jan 11, 2015 | 1998 Chevrolet S-10 Pickup
I have a 1998 chevy s10 with 195000 miles, drove home from work last night went out this morning started right up died out 45 seconds later, now wont start, battery is fine,and fuel pump is still making...
98 chev pickup s10 put gas in the gas tank drove it about 2days and the check engen light came on had it check mech said it was the gas cap replace the gas cap the light back on now what help
Dec 02, 2010 | 1998 Chevrolet S-10 Pickup
92 S10 When turn on HeadLights, Dash Board lights n Guage stop
i had an s10 blazer years ago that kinda did the same thing. the lighter socket was shorting out. so check the lighter and any power outlets you may have first thing. if it is the lighter its gonna be hot so be careful.
Sep 09, 2017 | Chevrolet S 10 Cars & Trucks
S10 Intermittent start, Electrical
Check you battery cables to make sure they are not corroded, and on tight. Check ground wires for the same, inside the engine compartment, and inside the passenger compartment.
Aug 26, 2009 | 2001 Chevrolet S-10
1998 Chevrolet S10 2.2 liter is popping
u need to replace the distrbuter cap and roter , clean the MAF by brake and parts cleaner
Mar 15, 2009 | 1998 Chevrolet S-10 Pickup
S10 pickup - engine won't start
when you put the kee on do you ear the gaz pump going if no get somebody to crank the the engine take a hammer and it the gaz tank most of the time the pump gonna kick in but get it check out you may have dirt from the fill up or simply change the gaz pump
Jun 20, 2008 | 1996 Chevrolet S-10 Pickup
PIAA 2002 Chevy S10 Pickup - All S10 Pickup models - Xtreme White Bulbs Logo
144 people viewed this question
Top PIAA Optics Experts
Lawrence Oravetz
Vernon Taylor
Are you a PIAA Optic Expert? Answer questions, earn points and help others
