Question about Sharp LC-32M300M 32 inch Multi System World Wide LCD TV
Sharp LC-32M300M 32 how do i reset the tv - Sharp LC-32M300M 32 inch Multi System World Wide LCD TV
Go to this for solution for lcd sharp volume and 'K' problem. http://jimus.mywapblog.com/service-mode-tv-sharp.xhtml
Posted on Mar 15, 2013
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
rulds2008
  • 3866 Answers
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 15, 2009
satavlad
  • 405 Answers
SOURCE: sharp flat panel tv,need manual for lc-19sb25u
http://www.sharp.ca/manuals/default2.asp
Posted on Oct 24, 2009
dsacco86
  • 1077 Answers
SOURCE: the TV will not turn on, any typical problems?
Not focused at your model pacifically. Typical problems like yours are happening to lots of other flat screen TVs in other brands.
Try leaving the TV unplugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 01, 2009
  • 8457 Answers
SOURCE: sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Posted on Aug 17, 2009
How to put the sharp aquos LC-32M300M into service
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 06, 2014 | Televison & Video
Sharp LC-32PX5M 32" LCD TV password
If you don't have password then follow as per attached file. Select factory reset.
Sep 25, 2014 | Sharp Aquos Televison & Video
My TV sems "stuck on a channel" and it iwll not move up or down and it is not responding ot either the tv controls or the remote. It is Sharp LC-32SB24U TV
Tries Unplug the tv and all devices to this tv.Replug it back about an hour later.Than goto the tv menu.Go to PICTURE go down to reset.It will reset the tv back to factory setting to the tv,everythings should work as before,not then ur tv manual control senor board or the Tuner board have problems,must be replaced to solved this.
Jul 05, 2010 | Sharp LC-32SB24U 32 in. LCD TV
If my Sharp Aquos 37in LC-40C37U tv needs to be reset how would I do that? Not getting any power, only a green blinking light. The power supply board checked out ok.
Blinking light is an error code. Count the blinks before they repeat. Check your manual in the troubleshooting section. If you can't find it, contact a Sharp service center or try and get a service manual. Reset info is also in the user manual but you can't do it if your set doesn't power up. Are you sure about the power board?
Apr 30, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Need a sharp 32 LC-32SB21U screen
Manufacturer Sharp Part Number LK315T3GW30R Description 32" VE PANEL ASSEMBL
Sep 04, 2009 | Sharp LC-32SB21U 32 in. LCD TV
Sharp Aquos 32 wont turn on
I called up Sharp, and if you are a part of Sharp AQUOS Advantage Program you get free in home service.
They were very nice about it, and I already have a technician coming to my house on Saturday and I called on Wednesday.
I doubt Sharp's policy alot less now!
Sep 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My sharp aquos 32' LCD has a heavy green tint to it. I tried reseting the settings back to factory settings, but it didn't help.
My sharp tv also had a green tint and resetting to facotry setting did not work, what finally worked is making sure that all cables were inserted all the way into the tv and receiver. Someone else advised this for another Tv and it worked on my sharp so it is worth a try.
Aug 19, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I need to receive a manual on the operation of my sharp tv
I believe your TV is a LC-32SB24U, not LC-325B24U.
You can download a manual at www.sharp.ca/manuals
Feb 21, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Sharp LC-32M300M 32 inch Multi System World Wide LCD TV Logo
1,035 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
