Question about GE Profile Spectra JGBP90 Gas Kitchen Range
SPECTRA GE GAS STOVE
3 BURNERS WORK FINE, ONE SPARKS AND YOU CAN SMELL THE GAS BUT I HAVE TO LIGHT WITH MATCH....
  • 11,896 Answers
Try cleaning the sparker with file to better the spark. If you can adjust the angle of the sparker closer to the gas nozzle would help to.
Posted on Jan 20, 2009
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I need to ge my stove lit
Does it have electronic ignition (clicking sound when starting) if it doesnt and you have an older model you may need to re light the pilot? Also make sure your getting gas to the unit (you will hear a hissing sound when the burners are turned on) try using a match to light the burner
Jun 25, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Ge spectra gas oven, stove works, but oven does not
the ignitor is bad. replace the ignitor and it will work perfect.
Feb 13, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Oven will not light
check the gas valve to make sure a mouse did not chew the wires.
Jan 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL 44
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL 44 Self Cleaning
Ray, sometimes the burners get gunked up. Remove the cap and burner and see if the small orifice that is located by the spark electrode is clogged. Clean it out with a paper clip. Make sure the burner cap has good contact with the burner. Catriver..post back.
Dec 06, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
141 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
