Question about NetGear WGR614 Wireless Router
Wireless Router says internet disconnected
Something up with the router?? My modem is working fine and I can get a direct connection through the modem. Laptop and game system (both use the router) indicate internet is disconnected. When I check the Net Gear connection in the laptop, it indicates I have an excellent signal however, it still shows the internet is disconnected (??). A logon screen comes up asking for 3 things, username, password and domain -- I typed admin for username, password for password and unsure of what the domain is?? not sure if that is the only problem. Any assistance would be greatly appreciated. Thanks.
  • jmcoleiii Jan 20, 2009
    We've already reset the router several times still nothing. We are showing that there is an excellent connection but still indicates internet is disconnected ?? Currently connecting directly from the modem. A logon screen comes on asking for username, password and domain....what are we suppose to type????
    I cannot find a list of Domain in pdf format under the Manufacturere NETGEAR. Do you have a website?
  • 19,396 Answers
You cannot find "list of Domain in pdf format under the Manufacturer", because such a thing does not exist.
Domains on the Internet are global and not local, and have nothing to do with this problem.
Regarding DNS, that is also fine, as the modem is working.
If the router has a built in Modem, that can be the cause for the problem.
Setting up the router to share modem internet connection in that case may cause more problems, it is not immediate.
Better to get a router with no built in modem.
If router has no built in modem, check the following:
Internet connection sharing must be disabled
1. Open the start menu, go to the control panel, and double click on your Network Connections (Single click network and internet connections first if you have a blue background on the control panel window).
2. If there are any network bridges here, make sure that those are deleted.
3. Find your Network adapter in use (if connecting wirelessly, you will be looking for a wireless adapter, if connecting via a wire, look for the local area connection that's enabled).
4. Right click on the adapter and select properties.
5. Click on the advanced tab.
6. Deselect an check mark made in the Internet connection sharing section.
Client for Microsoft Networks must be installed
1. Right click on "My Network Places" and choose "Properties"
2. Right click on the network adapter, and choose "Properties"
3. Click the "Install" button
4. Choose "Client" in the list and click "Add"
5. Choose "Client for Microsoft Networks" and click "Add"
6. Click "OK"
Posted on Jan 21, 2009
  • 8,197 Answers
Go to netgear start wizard you will find the domain there. Mine on net gear is 68.94.156.1 and 68.94.157.1 If you do not have the startup wizard software you can try to get it here. www.routerlogin.com/start.htm Once there go to maintenance router status to get your domain #. If you have any ? please ask befor you rate I have the same Router you have so I can look at my set up to help. Also did you configer the router with the startup wizard.
Posted on Jan 20, 2009
  • 124 Answers
There is a blue cable going from your modem to your router just unattach this for 5-10sec and reconnect and restart your computer hope this solves it for you
  • 6,487 Answers
What you can do here first is to connect the modem back to the router and your laptop connect it also wired to the router and check if you will be able to have internet connection that way, if it did connect to the internet when your connected wired to the router so the wireless settings of the router is the problem...
    Sergeant:
  • 378 Answers
Do system restore to your pc .by entering the old  date in your pc.when the router was working fine. click ---->start--->all programs---->assecories---->systemtools---->system restore----> adjust the old date.and then restart your pc if it prompts to.it will get adjusted.
  • 258 Answers
Connect with an ethernet cable and find out the IP Address
Also note the Subnet Mask, Gateway, and Primary and Alternate DNS values
To get these :-
1. Double click on Local Area Connection under Control Panel --> "Network Connections"
2. Click "Support" --> Click "details"
Enter these values for the wireless area connection like this :-
1. Click "Start" -- > "Control Panel" --> "Network Connections"
2. Right click on "Wireless Area Connection" --> select "Properties"
3. Click on "TCP/IP" (in th middle box) -- > Click "Properties"
4. Click "To use the following ip address"
5. Enter the values you got from wired connection above
6. If you get any duplicate warning messages ignore these
This will resolve the issue, I have used it many times
  • Peter Conway Jan 20, 2009
    If you do this and post the results I can tell you how to configure the router as you do not need the domain:-
    1. connect to modem with an ethernet cable, without the router
    2. assuming it's windows, start --> control panel --> Network Connections --> double click on the Local Area Connection --> Click details and post ip address, subnet, default gateway and both dns servers
    President:
  • 1,990 Answers
Welcome to Fixya! The Manufacturers Website has the List of Domain Names for your Area Available for Download in PDF Form.
  • 13,433 Answers
Press the reset button on the router for a simple reset, check the connections and see if its functioning now. optionally you can hold down the reset button for 30 seconds to restore default settings into the router.
  • Ekse Jan 20, 2009
    Where do you get this login screen? are you trying to login into the wireless settings?
    after you have hold down the reset switch for 30 seconds the defaults are restored, the default details are
    User ID
    admin
    Password
    password
L cannot get internet when connected to my router, but l get internet when connected to modem directly.
Your ISP allows only one device to connect to their network.
When you change devices (router versus computer),
you need to power-off the ISP's modem, and unplug it.
Connect the router to the modem, and connect your computer to your router.
Plug the modem back in, and the modem will "forget" what device was previously connected.
Feb 18, 2015 | BestPriceCables TP-LINK Ultimate 300Mbps...
Just had cable Internet installed and have had problems with it disconnecting every night at the same time, SB5101N Motorola. I have a wireless router, Belkin F5D8236-4, and was previously hooked up to my...
As long as your laptop doesn't have a firewall enabled then you should almost always be able to get connected by directly connecting your unit to the router.
Here is how to Determine if you Windows Firewall is enabled
Once it is disabled try resetting your Belkin back to Factory default Settings.
If all that still doesn't work I would attempt attaching it to the modem, and know once and for all if you router is working correctly.
Hope this help, and if it did please remember to leave Feedback/Testimonial. Thanks.
Mar 21, 2011 | Arris SURFboard® SB5101 Cable Modem
Wont connect to playstationnetwork
Check it out. If you r constantly getting connection interruptions during game-play then here is what u need to do. If u r using a router (no matter the brand), the problem probably has to do with the router. In order to find out, disconnect your PS from the router and plug it directly into you modem. If your modem is not near your playstation then move it close to the ps3. The modem plugs directly into your cable line so there is a good chance that the television you play your PS3 on has a cable connection. One you have connected your PS to your modem press the reset button on the modem. Turn your PS on and go directly to your network settings. Click on Internet Connection Test (do not bother trying to set up a connection manually, if you do this chances are you will mess something up). If you are getting a connection then you are ready to go. There is a good chance you may never get a connection interruption again. For the time being you will be able to enjoy playing call of duty like you once did. Now u might ask what am i supposed to do with my router? I need it for my laptop, xbox, etc? Just buy a new one. Chances are the one that you have is garbage. It might have worked great at once, but hey, these things happen. I suggest doing your research and find a router that works well with gaming. I hope this works.
Any further questions please feel free to ask.
Nov 20, 2010 | Sony Playstation 3 (PS3) Console
For no reason, my HP laptop stopped working the internet. It works perfectly otherwise. I hard connected the laptop directly to my wirelessouter as well as my modem, still it will not connect to internet.
Connectivity issues can be many.
I would start my first rebooting the main modem.
Once that is up, reboot the wireless router.
Once that is uo, reboot the laptop.
Try to connect.
If that does not work, eliminate the wireless router and connect the laptop directly to the modem via Ethernet cable and reboot the computer again and see if it works. If it does, then it is something with the wireless router. If it doesn't, i would contact the provider so they can verify that they can see your modem on their network. If they cannot, they will advise you further (hardware/cabling issue). This is all assuming that nothing has been changed on any settings of the laptop, router or modem.
Jul 21, 2010 | HP Pavilion dv6000z Notebook
Router stopped broadcasting wireless signal
Can you connect directly via cable to the router? If not, the system may be toast.
To make sure everything is clear. Turn off your modem, router and pc. Next power up the modem, the router and the pc in that order.
A possible cause of your problem may be that you had no security on your router and a neighbor mistakenly reset the router to another name or something.
If you find that you can connect to the router directly, I would setup security on the network.
If this helps, please rate me. If you need more help, please write back.
May 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a linksys wireless g router that worked fine until yesterday. Now it won't connect to the internet. I have a desktop wired to the router and a laptop used wireless.
Check if you can connect to the internet when hooked directly to the modem. If your connection works fine through the modem, then your router needs to be reconfigured.
May 13, 2010 | Linksys Wireless-G WRT54G Router
Running install disc, says does not support operating system
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 03, 2010 | NetGear WGR614 Wireless Router
My dir 300 is working fine but it disconnects from the internet
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 09, 2010 | D-Link DIR-300 Wireless Router
US Robotics Wireless Router problem
Sounds like some settings on the wireless router might be setup wrong...like DNS. While hooked into wireless, try going to a command prompt and type ipconfig /renew. Once it refreshes, type in ipconfig /flushdns. Try the Internet.
If that doesn't work then check the settings on the wireless router and see if the DHCP is setup with a static IP or dynamic one.
Depending on what that says, I can provide next steps.
Apr 11, 2009 | Dell Computers & Internet
NetGear WGR614 Wireless Router Logo
26 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
