Question about Garden
Can't remove snowblower muffler rusted in place
I have an ancient snowblower the "barrel-like" muffler of which screws directly into the side of the engine and is rusted into place. Have tried spraying where the threads enter the side of the engine with "Liquid Wrench" and, later, WD-40, lightly tapping the inlet pipe with a wrench while spraying so that the vibration will help the liquid penetrate, but I still can't get the muffler/pipe to unscrew even a millimetre. Can anyone give me some tips? Have heard that "naval gel" is good for such situations, but searching for that turns up nothing on hardware chain search engines. Thanks
  • John Jan 10, 2013
    Have tried Liquid Wrench Super Penetrant and, later, transmission fluid & acetone to no avail. Will now just cut the muffler pipe an inch beyond the threads and have a welder braze a new muffler to the "leftover" piece of pipe - should have thought of that first and saved myself $20. Thanks for looking.
    New Friend:
  • 109 Answers
Soak an old cloth in coca cola and wrap it then pour the rest of the coke over the area give it 10 - 20 minutes and tap it with a hammer or mallet
Posted on Jan 16, 2013
  • John Jan 18, 2013
    Thanks for the advice; however, tried that previously in a diff situation and found that Liquid Wrench was more effective.
kachbibi1
  • 979 Answers
SOURCE: snowblower: fire from muffler
Try changing the spark plug. You may be having some misfiring going on here. Is your fuel to oil mixture right?
Posted on Feb 03, 2009
  • 2468 Answers
SOURCE: trying to replace the pull cord , can't get last
use an impact wrench it will hit the nut so fast it will loosen it befroe the engine car turn over
Posted on Mar 21, 2010
Testimonial: "Worked like a charm!!"
radar001
  • 1051 Answers
SOURCE: I have the same problem as gjmaag2, I removed the
If the plug is wet your fuel air mix is too rich. Increase the air in the mix and you should be fine. To increase the air adjust the screw on the side of the carb.
Posted on Oct 03, 2010
  • 72 Answers
SOURCE: i have the homelite yard
Hi, your problem my lie with the carburetor. There is what is called a needle valve that is regulated by a spring loaded rocker. This assembly may be out of adjustment causing your motor to starve for fuel when there is higher demand. These items are small and require a steady hand to disassemble and reassemble. Most carb rebuild kits come with the specifications that you require to make this adjustment. Hope this helps!
Posted on Nov 16, 2010
  • 85 Answers
SOURCE: I have a Tecumseh 5
try changing the plug may not be getting enough spark to start
Posted on Feb 07, 2011
How to remove chainsaw muffler
If this is the Husqvarna 440, there are two allen headed screws sunken down inside the holes in the front of the muffler, its either a 5mm or 6mm long arm allen key required.
Jun 16, 2013 | Husqvarna Chainsaw 440E-18
Manual for wearever super shooter cookie press
Instructions hand copied from my old manual
1. Stand motor on flat surface; screw barrel securely into place.
2. Attach flat side of piston onto screw and turn far enough to see 1-2 threads
3. Insert assembled piston/screw in barrel so that notches in piston line up with the ribs in barrel; snap screw into place.
4. Fill barrel with desired mixture, using small amounts at a time and tamping into place with barrel loader; wipe any excess mixture from exterior of barrel
5. Select desired cookie disc or tip; place on filled barrel
6. Attach cap to barrel; tighten securely in place. Note: machine may be operated with barrel partially filled
Note: If cookies do not cut off properly even though dough consistency is correct, make sure the 3 feet of the barrel cap touch the cookie sheet each time in order to form the cookie. As the gun is lifted, the flow of dough is cut, forming the cookie on the sheet.
Nov 23, 2012 | WearEver Wear-Ever Super Shooter Electric...
Ford Escape with rusted, broken bolts/muffler hanging loose from catalytic converter estimate/fix
That is a pretty common issue with the escapes. Most of the time the broken bolts can be removed and new bolts along with a gasket can be installed and everything is fine. Sometimes the flanges are to rusted and the two pieces need to be replaced. Just depends on the vehicle.
Aug 13, 2012 | 2005 Ford Escape
Proform 730 treadmill,rusted screws won't remove to replace walking belt
Use WD40. Or go to a nearby hardware store an purchase a rust remover. Aply either one and wait for a bit. Then remove screws.
May 06, 2012 | Proform Exercise & Fitness
Tailpipe rusted off muffler, or Muffler piece rusted letting go of Tailpipe, easy fix?
Easy is a relative term. If you can get the remainder of the tailpipe off from the muffler, replacing the tailpipe alone wont be so bad. If it's in there so bad that it will take all day to remove, I would recommend replacing the exhaust from the cat back because it will end up being faster and easier. If you plan to keep the vehicle for any length of time, specifically ask for walker exhaust components; AP mufflers and pipes are a little cheaper but wont last.
Jun 27, 2011 | 1998 Jeep Grand Cherokee
I am trying to replace the belt on my bissell. The directions state "remove the screw that holds the red retainer in place, set red retainer arm and screw aside. I see the red retainer but can not get...
Did you release the handle first before you flipped it over?
Have you removed the screw and it still won't come out, or is it stuck even after the screw is out?
Are you having trouble getting to it?
Please reply back with more info.
Thanks,
Handie Andie
May 09, 2011 | Bissell 1699 ProHeat Clear View Upright...
I have a toro snowblower that quit running last year. The screw which held the choke plate in place is missing and I can't find it. Is it possible the screw is in side the motor? I removed the carburater...
Hi
I have seen them go through the engine into the muffler. Did you check the valves if it damaged them. I would check for spark first if that is good put a tea spoon full of gas in the spark plug hole and try to start. If it fires you need to clean the carb. If not i would do a compression test that will tell you if the screw damaged anything.
Sam
Jan 08, 2010 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Dishwasher makes a high pitch whine when it runs
instead of motor check out the motor impeller that can make the high pitched noise if rusted or cracked. ------------- Motor and pump assembly screw and impellor help....
One of the most common question that I get on a dishwasher repair is "how does that motor and pump impellor screw come out?"
Inside many dishwasher pump assemblies is a screw that goes through the upper impellor and screws directly into the motor shaft. Since the motor shaft and screw are made of metal...you guessed it...they can / will rust. The screw can rust and become very tight and difficult to remove!! These screws are normally a right ( regular ) hand thread, socket or nut driver can be used to remove the screw. One hard thing to do is to hold the impellor still so the screw can be removed, they often just turn together. The impellor may be jammed with a screwdriver to hold it still so the screw can be removed...sometimes the impellor can be help still by placing a rag on it and hold tight with your hand, the rag will help prevent a sharp edge on the impellor from cutting your fingers. The odd time that screw is too rusted into place, soaking a little rust buster or 3in1 oil on it over night may help loosen it. Sometimes trying to tighten the screw a little at first will help break it free. There are some tool ( see below ) that can be purchased to help hold the impellor still so the screw can be removed, these are only for a few models and pump assembly styles.
WLP seal tool helps center and install the pump seal
Frigidaire seal - impellor remover and install tool
Once the screw is removed, the next obstacle is the impellor can also get stuck onto the motor shaft. Many times I have to break off the old impellor. A sharp blow straight down with a hammer and flat screwdriver will often crack the plastic impellor...careful not to damage the pump body! If the motor shaft has indeed rusted, clean it up really good with sand cloth.
Apr 03, 2009 | KitchenAid Dishwashers
Snowblower: fire from muffler
Jan 28, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
