Question about Sewing Machines
Kenmore Sewing Machine Model #158.18032
The feed dogs cannot be lowered on my Kenmore Sewing Machine Model #158.18032
    New Friend:
  • 186 Answers
You probably have a bind in the feed dog mechanism. If you can remove the covers and manually force them down you will see the hinge points that need to be oiled.
Unplug first!
Good luck.
Posted on Jan 30, 2009
Kenmore Sewing Machine Model 385.16221 feed dog is stuck down,m the lever just does nothing. It lowered feed dog, then was useless when I went to raise it to position.
your machine will have a flip type opening at the very front of your machine above the area where the needles are attached to the arm that moves up and down ( it usually has the light globe installed in there ) after opening that door you will see where the dog feed is attached to it should also have a spring that helps the dog feed return to the up position when not in use , make sure it is not stuck in any way and some lubrication oil should be used to prevent it from sticking , while using the dog feed release button push the spring in a up and down motion to help it to dislodge
Oct 28, 2017 | Kenmore Sewing Machines
How to lower the feed dogs for free motion sewing on model # 16782
There are most likely some numbers missing from the model number you provided. Usually, there is a 3-digit beginning number, ie 115, 385, 401...
I am unable to find model information based on your number, but you can most likely get a user's manual through Sears or try searching the internet (Make Model manual), ie:
Kenmore Sewing Machine Manuals Instruction and Repair Manuals
Sewing machines generally have two ways to disable feed dogs. One way is a lever or knob on the machine itself that physically "drops" the feed dogs so they are below the needleplate. The feed dogs will continue to operate but since they are below the sewing surface, they will not have an effect on the fabric movement. The other way is an accessory that attaches to the needleplate which covers the feed dogs and creates a flat sewing surface.
Another item that is important for free motion quilting is a darning foot or free motion foot. These presser feet are physically shorter in height than a standard presser foot. This means the darning foot, when lowered, does not apply "pressure" to the fabric when it is lowered. It, instead, provides leeway between the presser foot and the fabric so there is room to manually maneuver the fabric while stitching.
You'll just need to CONFIRM that the presser foot shank is correct for your machine (low shank, high shank, slant shank).
There are probably a multitude of designs available for your machine, either Kenmore or generic brands. Once you've determined your machine's shank, it would be a personal decision as to the design you'd prefer, which could be metal or plastic, closed, open, or clear see-thru as well as various shapes, round, oval, etc. There are also some feet that are spring-loaded so they "hop" while you stitch, or feet that are solid.
These are examples of different darning/free motion presser feet.
Darning Foot Low Shank 4021
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Amazon com Tinksky Sewing Machine Open Toe Metal Quilting Embroidery...
Free motion Darning Quilting Sewing Machine Presser Foot Fits All Low...
Nov 27, 2016 | Kenmore Sewing Machines
Kenmore sewing machine feed dog
Probably it is the spring loaded cam on the lower shaft not moving as it is bound up. The feed drop lever pushes it to the left to lower the feed dogs, but it has to spring back on its own after you move the lever back.
If you can remove the lower free arm cover you may be able to work it loose. Do not use 3 in 1 oil as it is gummy. Better to get Lilly white sewing machine oil.
Hope that helps!
Mar 12, 2014 | Sewing Machines
I have a Singer sewing machine, Model 385 12314990. I cannot find how to lower the feed dogs. I read another suggestion about taking off the side plate and the feed dog latch is behind the...
You probably have a plastic plate to put over the feed dogs, I think you have a Kenmore sewing machine not a Singer because of your model number. If, still can't do it, take it to Sears sewing machine department and have them show you. Most of them are really nice and it is free.
Mar 16, 2011 | Sewing Machines
Kenore Sewing Machine - Model 385-1960180
In the very back near the front but just beneath the bed of your machine, you will find a flat button. Push the flat button and it will lower your feed dogs. I have this sewing machine and I love it.
Apr 17, 2010 | Kenmore Sewing Machines
How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Aug 25, 2009 | Janome Memory Craft 5700
Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Sep 20, 2008 | Sewing Machines
Feed dog
There is a black lever behind, above and to the right of the needle.
Aug 24, 2008 | Kenmore Sewing Machines
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
566 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
