Question about Canon P170-DH Calculator
How to change the fuse in canon p170-DH - Canon P170-DH Calculator
SOURCE: Canon P170-DH
I played around with mine and found the keys that you change the time and date with by looking over the top of the keyboard. On my model there is a time and date key that has a little calendar and clock actually on the key. That key allows you to switch between date and calendar. After you click on that button you will either see a date or time. To change those numbers use the following keys: The equal (=) key will change date and time by holding the key down till the numbers on the display start to flash. Once they start to flash use the number keys to make your changes. The multiplication (X) key you can use to change am and pm. If you want military time use the division key. If you are changing the date there is an additional key that lets you change the format. What this means is the sequence on the display by the way you view the month, date and year. You can change it so year shows first then month and date or interchange day and month. Once I found those keys it was easy.
Posted on Mar 11, 2007
old marine
  • 2148 Answers
SOURCE: Setting tax rate on a canon P170-DH
To set the tax rate, slide the "GT" switch to RATE. Enter the tax rate (i.e., 4.5 for 4 1/2 %). The display should show 4.5 %. Slide the "GT" switch to OFF.
Posted on Jul 30, 2008
SOURCE: Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Posted on Feb 17, 2009
for calandar
turn on.
press clock calandar button, top row second from left.
press time set button, second row from left, 3rd button from top, (has time set printed diretly above)
enter numbers, say 03 05 2009
press time set button 3 seconds
press CE/E, red key at bottom left corner.
turn on
press clock calandar button once, date will show
press clock calandar button 2nd time, clock will show
press time set once
enter time
press am/pm button (below time set)
press time set for 3 seconds
press CE/E red button to return to calculation mode
thats it
Posted on Mar 06, 2009
SOURCE: Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
Posted on Nov 24, 2009
Where is the time set key on canon p170-dh
Press the button to the right of the FEED button twice. The first time you press it will be for the Date, the second will bring up the time.
May 13, 2010 | Canon P170-DH Calculator
Loading paper into the Canon P170-DH Desktop adding machine
Rather than try to describe the process in words ("lift up the arm, then feed the paper through..."), I'll point you at the illustrated instructions in the manual at the manufacturer's web site: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=349&modelid=9785
Mar 03, 2010 | Canon P170-DH Calculator
I lost my manual how do I can;t get my paper to
Canon website says For your convenience, a copy of the manual for the P170-DH is now available on the Drivers & Downloads tab on the consumer site. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=253&modelid=9785#ModelDetailAct
Jul 30, 2009 | Canon P170-DH Calculator
Nov 20, 2008 | Canon P170-DH Calculator
Canon P170-DH
Refer to the illustrated instruction on page 4 of the instruction manual available on the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=349&modelid=9785
Oct 17, 2008 | Canon P170-DH Calculator
Jul 30, 2008 | Canon P170-DH Calculator
http://downloads.canon.com/cpr/software/calculator/P170-DH-(USA-HWB).pdf
Oct 15, 2007 | Canon P170-DH Calculator
Canon P170-DH Calculator Logo
96 people viewed this question
old marine
old marine
