Question about ASUS Eee PC T101MT 320GB Professional 10.1" Multi Touch Screen Netbook
Toushscreen do not work
I installed the windows 8
  • ASUS Master
  • 27,725 Answers
Connect the screen to a computer running Windows 7 using the supplied USB cable and a cable for the video signal. Ensure the cables are properly connected. If the screen does not respond to touch, please visit our knowledge base article USB detection problems in Windows. or you might use the system to restore to resolve the problem You can use the System Configuration utility to perform a system restore. There are three possible restore points: System checkpoints that Windows schedules Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. hope this helps
Posted on Jan 09, 2013
How do I get help with my AS240 transcription kit, it won't work with my Windows 8 laptop
You probably need the driver for Windows 8. Check Olympus website for downloads or support for driver.
Oct 06, 2014 | Olympus AS2400 Transcription Kit...
Dual boot xp with windows 8
No solution now, Install Windows XP again on first partition, Make sure BOOT.INI, NTLDR, NTDETECT.COM in the same partition in which Windows XP is loaded. Then install WIndows 8.
OR in the current scenario you've to do much technical work using third-party tools.
Feb 27, 2014 | Microsoft Windows XP Professional With...
Can I install windows 7 in my windows 8 computer
Yes you can for as long as there are drivers which compatible for windows 7. What is the build of your computer?
David
May 26, 2013 | Computers & Internet
Can asus k42f be ugraded to windows 8?
Windows 8 has updated drivers as much as you would get from Asus built into win 8.
Go to devise MGR, if windows 8 did not load drivers, you will see a flag.
See what hardware did not load a driver and then use the win 7 driver.
You don't do anything to make a win 7 driver work, if the driver is newer, and signed it will install, if it's older then the driver windows installed, it won't install. If you see a flag and windows did not install a driver, then try the win 7 driver, or go to the MFG of the hardware and see if there is a win 8 driver.
You can also run windows update, if win update see's a newer driver out it might pick it up and give you a install option.
Now, your chipset, and most hardware has windows 8 drivers out.
The drivers are the biggest problem, the biggest problem for you is the BIOS was not set for windows 8.
So you could find even with the best drivers, win 8 slower or has bugs more then win 7 will have.
Me, I would bench test all the hardware with win 7, then with win 8 and see which one is better.
Apr 08, 2013 | ASUS K42F A1 Notebook
How can I install Windows 8 on my computer with M2N MX SE motherboard?
Hello try the asus homepage here:
http://support.asus.com/Download.aspx?SLanguage=en&m=M2N-MX&p=1&s=24
The vista drivers should work, when you install windows 7 again.
The files has to be unziped, before you install the driver.
But that does not mean the drivers will work on win 8.
Here are the other models of the mainboard:
http://support.asus.com/Download/ModelList.aspx?SLanguage=en&keyword=M2N-MX&type=1
Consider to buy a new mainboard, that supports win 8.
A new mainboard cost around 100 dollars, and the cpu aswell.
You maybe have to buy new ram, because all new mainboards have ddr3 ram.
Good luck
Mar 11, 2013 | ASUS M2N-MX Motherboard
Aspire 5532 won't load windows 8
Hello you can test here:
http://windows.microsoft.com/en-US/windows-8/upgrade-to-windows-8
If the pc is compatible to run windows 8.
If it fails, the pc is not capeable to run windows 8.
Here is no drivers for windows 8, at the support site:
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=1290
The solution is to continue useing windows 7, or buy a new pc with windows 8 installed.
Good luck
Feb 09, 2013 | Acer Aspire 5532-5535 AMD Motherboard...
Cant install windows 8 pro on sr1460an
Have you checked the system requirements for windows 8?
Are you leaving it long enough to complete the install process?
Jan 20, 2013 | Computers & Internet
Asus 53 n laptop
1. option - Removing Windows 8 by installing Windows 7 over it*:
Go to the disc where you have the Windows 7 installer.
Then right click, click on Mount, when done, click on the Setup file and install Windows 7 over your current system.
2. option - Keeping Windows 8 and installing Windows 7 alongside it**:
Restart the Windows 8 system, before Windows logo shows up, keep pressing F12, then choose the disc you have Windows 7 .iso file on.
3. option - Running it from a DVD, but keeping/removing*** Windows 8:
a) go to the disc where you have the Windows 7 .iso file installer.
b) move the .iso file to a easily accessible place like Desktop.
c) then right click on the .iso file and click on Burn disk image, choose the DVD you want to boot from ( You need a readable DVD), and then check the checkbox which says " Verify disc after burning ".
d) click on Burn.
e) when that is done, close all open programs or/and windows and restart your computer, before Windows logo shows up, keep pressing F12, then choose the disc you have Windows 7 installer on.
Note - please read everything carefully. I suggest you to use the 3. method.
* - when in the setup, you have no option to go back to Windows 8.
** - this step might not work, because not all computers support that.
*** - you can choose to either create a new partition on which you will install Windows 7 or install it over Windows 8 by either kepping or not keeping your personal files.
Please reply to this solution: did it help you or not and what improvements in my solutions do you want, and rate my solution from 0-5.
Jan 12, 2013 | Computers & Internet
I need free mgi photosuite se for 64 bit windows 7
If you have the original CD's then follow next:
Just today I was able to get PhotoSuite 4 to work in Windows 8. PhotoSuite 4 (P.S. 4) is dependent upon Internet Explorer 5 (I.E. 5) browser for its content/software to work. The original P.S. 4 CD has
I.E. 5 installer, I tried to install and the install quit with a check box to force install of all components. Internet Explorer 10 for Windows 8 was not affected in any way, that's how I got back here anyway.
I have read ton's of suggestions and one mentioned I.E. Browser dependency and walla it was the answer that took me ten minutes to get it up and running. P.S. 4 worked in windows 7 (update), not full install for me so I assume original I.E 5 files were replaced full install windows 8.
Jan 04, 2011 | MGI Software PhotoSuite SE V4.0
ASUS Eee PC T101MT 320GB Professional 10.1" Multi Touch Screen Netbook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
