Want to know vertical ic no of tv model no 21sa1rg3t8
Tv model no 21sa1rg3t8
Vrya
  • 62 Answers
SOURCE: Kv-36xbr800
Hiii...
My version is :
For safety reason you should replaced them ( Horizontal ic,Vertical ic, Deflection ic) and olso all the big capasitor nearest the ic....that's my version....if you have big budget for it....he..he....
Thank's
[Vrya]
Posted on Feb 19, 2008
  • 11 Answers
SOURCE: sony tv model no. KV - 19 APR 2
This is for a different model, but I had thin horizontal lines in red and had to adjust the tube for red. You may have a similar adjustment on your set.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Aug 14, 2008
ginko
  • 19396 Answers
SOURCE: Dear Sir: I have a Toshiba 27 tv vcr combo tv.
Hi.
Here IC specsheet:LA78041
Also replace the 100uf/35 volt cap on pin three of the IC and the two zener diodes connected to the IC. That is part of standard repair. If you don't replace the whole lot the IC may blow again.
Here the IC for sale. Cost is less than $5.
Posted on Sep 08, 2010
SOURCE: memorex tv model mt 2274
i have memorex mt 2274 tv's complete service manual ( 2.73Mb size) - everything is given in that manual - kindly send your email address to me i will attach that manual & send to you (free of cost) - below i have shown sample picture from that manual - check components number & value given in this sample picture with those on your tv board to confirm this manual matches with your tv's main board - i got that manual from below shown website .....iam service engineer from bangalore ( computers, laptops, ups, printers, etc... -
Posted on Jun 14, 2011
gopakumarg43
  • 75178 Answers
SOURCE: my sansui tv has vertical line problem ic tda9370ps/n3/a1932 and vertical ic stv9302A
It sounds that the kit is a Chinese one. Check the voltage to all terminals of vertical output IC. Check and replace it. This is a common problem to these kits.
Posted on Aug 23, 2012
Vertical IC of LG TV model 21FD1RB-LD
It's preset @ Factory in Chipset, Follow You're Warrante Procedure's
Jan 21, 2014 | Televison & Video
No picture. Sound is OK on Philips DPTV345 model 51PW9303/17F
I would check the solder on the Vertical output IC as ofetn the soolder will crack and the CRts will shut down to prevent damageing the CRts when vertical drops out. If the solder looks good I would try replaceing the vertical IC very inexpensive and you can get the vertical IC from www.tvrepairworld.com
Feb 10, 2013 | Televison & Video
The vertical ic of my jvc tv model no. av f21mx5 are always burn even i replace a new one
Just check the supply voltage input to the vertical IC. If it is more than normal, this type of fault can occur. Just compare this voltage . The TV schematic will help you to find this detail. Check whether the IC is firmly screwed on to its metal heat sink.
Jul 03, 2012 | JVC AV-20020 20" TV
DeawooTV Model DTC 2975 I want to know about vertical ic number.b,cos i can't fine out the number that ic is burn.
Hello
There are two mumbers used in Dawoo tv as vertical IC.
If used is a [9] pin one number is [TDA 8357J].
If used is a [10] pin one, number is [ LA 7848]
OK.
Jan 05, 2011 | Daewoo Televison & Video
DEAWOO TV Model no DTC 2975 vertical line i want to know that vertical ic number b,cos of that ic is burn & blast,i can't fine out.
If you have a bright vertical line down the screen you have an "S" correction fault. Usually there is a small choke that gets a dry joint under it.
Check for dry joints.
Jan 04, 2011 | Televison & Video
Sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Feb 25, 2008 | Sharp 27C-240 27" TV
Vertical black lines rear projection
Please provide exact model from back of tv........
Possible vertical IC circuit problem===bad caps? IC?
...........T.
Nov 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
My phillips ts2746c221 model
If it is a horizontal line is straite or zig zag, if it is straite then problem in your vertical section,please check the supply of vertical section or output ic of vertical, if it is zig zag line then it could be dry solder in the yoke connector or vertical yoke open, please let me know the vertical ic no.
Oct 22, 2007 | Philips 27PT71B 27" TV
Part help
the vertical o/p generic number stamped on the fron of the ic is "TDA8172" the sony part number is "8-759-980-58". good luck
Mar 13, 2007 | Sony KV-27S65 27" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
