Question about Canon PIXMA MP150 All-In-One InkJet Printer
Alignment how do i align my canon pixma mp150? have lost the manual
  • 315 Answers
Http://software.canon-europe.com/products/0010247.asp
scroll down to number 84.
This is the manual for the MP150.
Posted on Jan 21, 2009
I have just replaced the coloured ink in my Canon Pixma MP150 Series Canon Printer and the ink is printing out very faintly on a couple of photographs, How can I make the printer print a good colour
Try to do some cleaning and alignment. You can access that by going to your printing preferences and clicking on the maintennance tab. Or, pull up the document that you want to print. Click File, then click print. Click on Printing Preferences and click on the Maintennance tab. The tab would have different levels of cleaning.
Apr 28, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My canon printer all in one have a line in the printing paper
It sounds like you need to run printhead alignment.
Though I cant find a manual to tell you how to do it but
You can download the software http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=12764. You'll need to select your operating system.
Hope this should fix the problem.
Jul 15, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Hi there Im not very expert at using printers and ive lost my manual. Im using a canon mp140 pixma. the problem is there is a triangle with a lightning bolt in the middle this is lit up. the B and C...
Here is a link to Canon for your Pixma MP140. Troubleshooting Section. E, 5
The FINE Cartridge cannot be recognized.
Possible causes are as follows:
bullet_s.gif The FINE Cartridge may not be installed properly.
bullet_s.gif The FINE Cartridge may not be compatible with this machine.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15294
Nov 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Vista for canon pixma mp140
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Hope this helps - fotobean.
Help, lines have appeard accross my prints.
Whenever lines begin to appear across the top the cartridge is no longer set properly. Take cartridge out and then re-set back in. That will take care of it.
Don't forget to rate this solution.
Jan 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Lost manual and need to peplace cartridges on pixma mp150 printer
I asume that your printer is an Canon MP150 since you posted your topic under that
so...here u go, here is the manual...and all other avalible things from Canon to your model
http://www.canon.com.au/products/all_in_one_printers/all_in_one_printers/mp150_support.aspx
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Need a cd driver for my pixma mp170/mp150
Click on PIXMA MP170 ink above, look down to wiki manuals for acticle relating to Drivers/lost cd in that acticle you will find a link to canon download page.
Dec 26, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
244 people viewed this question
old marine
old marine
