After unplugging the tv the light goes red. Pressing either the remote power or tv button power the tv turns the light green (solid) and then no picture. After the light turns green none of the buttons on the remote or tv work. The picture doesn't turn grey.
SOURCE: theres no picture on my sony bravia KDL-40S4100
Try pressing the TV/Video button. The problem could be that the TV is set to an input with no source.
SOURCE: will not turn on
Power supply board have dead leakage gases componnents call capacitors.These capacitors are dead or will not work properly.These capacitors alway bulges up it top or puff up it top.U know basic electronic's and soldering?Take ur tv aparts.Go all around the power supply board searches for these bulges or puff it top capacitors.Replaced these leakage gases capacitors,ur power will return to normal functions,and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
SOURCE: Sony Bravia 32". After Powering On within 5
In order to properly diagnose the problem and provide a solution, the following information is required:
1) Model number (on the back of the set)
2) The count of blinks of hte standby light.
The standby light should be blinking in a repeated pattern of a count followed by a short pause then the count again ...
This count is an indication of the circuit that has the fault. With that information and the model number, I can list the likely causes and fixes.
Thanks,
Dan
