Question about Dell Precision 380 P4 Dual Core 3 GHz (99382) PC Desktop
What is GND signal name? - Dell Precision 380 P4 Dual Core 3 GHz (99382) PC Desktop
  • 61 Answers
That would be GrouND
Posted on Jan 08, 2013
TW10794V-0
If you tell us what the monitor is doing, the solution may not require knowing what voltage is at what pin - especially since some of the voltages may be oscillating!
Dec 12, 2012 | Sharp Computers & Internet
My smasung monitor sync master 753 vga connector broken, what is color scheme for new connector
Colour scheme to re wire is as follows...
Pin Name Function 1
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Hope this helps!!
Jul 19, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
No signal detected
signal cable may disconected or brocken inside check the following connection
1-red
2-green
3-blue
4-gnd
5-gnd
6-red(GND)
7-green(gnd)
8-blue(gnd)
9-+5v (from vga card)
10-stand by
11-synchronus gnd
12-sda
13-Hsync
14-Vsync
15-Scl
see whether ground is disconnected or not also check the continuty from pcb to crt base
Mar 20, 2010 | BenQ Computers & Internet
Shrinking of the display
The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Aug 10, 2009 | SAMTRON 55V 15" CRT Monitor
Cannot get sound using dvi cable
DVI is digital VIDEO interface, you will need a seperate cable for audio
Jun 15, 2009 | HP w1907 LCD Monitor
Dell 1800FP, no signal found (analog). Green LED on, get message
check if your signal cable is properly connected to your system unit and make sure that non of the pins of your signal cable is broken.if any of the pins are broken,try and change the whole signal cable and re-connect it again
after following the above instruction,reboot your computer
thank you for contacting as with your problems,you are always welcomed
Jan 26, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Pinouts for Hirose 41 pin connector on panasonic LCD DL3DE0127BAA
I am attaching the image. This is standard 41 PIN Hirose connector for the LCD TV. It doesnt matter who is the manufacturer because all LCD TV has to abide with the Industry architecture. For more information click this link :
http://www.geocities.com/p9019/lcd/LCD_Panel_Pinout.html
Nov 01, 2008 | Computers & Internet
Power supply
ATX Version 1.2 - 20 wire motherboard connector Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 Pin 9 Pin 10 3.3V 3.3V Gnd 5V Gnd 5V Gnd P_OK 5VSB 12V Oran Oran Blk Red Blk Red Blk Gray Purp Yell Oran Blue Blk Green Blk Blk Blk White Red Red 3.3V -12V Gnd P_ON Gnd Gnd Gnd -5V 5V 5V Pin 11 Pin 12 Pin 13 Pin 14 Pin 15 Pin 16 Pin 17 Pin 18 Pin 19 Pin 20 The color scheme used for the voltages in the 20 pin connector holds for the other ATX standard power supply connectors. However, brand name manufacturers often build proprietary power supplies or make up their own color coding, so I wouldn't throw out a power supply that supplies 5V where you think it should supply 3.3V. It's more likely a proprietary design than a failure.
Feb 21, 2008 | Computers & Internet
Samtron 78DF signal cable conductors
This is solved by the author himself
May 30, 2007 | SAMTRON 78DF 17" CRT Monitor
Computers & Internet Logo
Alun Cox
